How much boost is safe for me?
I've got a TME Turbo, Injen FMIC, and ARP Headstuds....I'm running 25psi right now...could I go higher safely? and would I need a re-tune?
Need to get tuned and look at your AFs if you intend to go higher.
You can spike all the way upto 32psi with a proper tune... I'd recommend to stay at 28psi ~ 30psi with a proper tune... and keep in mind, you can run leaner if you're spraying meth/alky.
