running rich
Old Sep 2, 2005 | 03:02 PM
jxn evo 8's Avatar
running rich
Ok I know that the best solution to my problem would be to put my car on a dyno and have it tuned but Mississippi just doesn't have AWD dynos and tuners all over the place. Anyway my question is my car is running rich when I hit around 4000rpm to redline. I know this b/c my air fuel guage is telling me this. I am currently running stock boost. If I wanted to lean my car out a bit on the top end would the best thing be to buy a MBC and raise my boost to maybe 21-22lbs of boost. or is a reflash the best option for me. I am running 600cc AMS injectors and I also am running an Apex ****-II. other mods include cold air intake, AMS intercooler, cat delete. these mods were already on the car when I bought it. in the next month I am planning on installing cams. anyway any advice would be greatly appreciated.
Old Sep 2, 2005 | 04:52 PM
jmartinez1170's Avatar
where is your a/f at
Old Jun 9, 2006 | 04:33 PM
bluebyu36's Avatar
dude u have after market injector's with no tune
Old Jun 9, 2006 | 04:36 PM
lancealott's Avatar
You are probably losing a pound of boost just because of the bigger intercooler on the stock turbo. I say make the trip for tuning. Get cams and a boost controller and get it tuned, you will be a happy man after that.
I lost one pound when I uprgraded to the Perrin intercooler on stock turbo. Poor lil evo.
Old Jun 10, 2006 | 06:03 AM
kjewer1's Avatar
Turning up the boost will not lean out the AFR, unless you are out pacing your fuel system. On a stock pump on stock wiring and over 20 psi this is likely the case anyway. But, I feel it's important to mention that aside from that, raising boost won't lean out the AFR. The ECU will see any added airflow and add fuel proportionately. And if you move up to the next airflow/rev breakout it will actually richen the AFR.
Old Jun 10, 2006 | 08:02 AM
platinumspecv's Avatar
get a real wideband o2 sensor with gauge and start leaning out ur AFR's with ur AFC. You didnt get your SAFC to sit there and look pretty.
Old Jun 11, 2006 | 06:30 PM
bluebyu36's Avatar
all air fuel guages are going to read rich u cant go by that
beasters
Dec 31, 2018 10:57 AM
crf inc.
Lancer Aftermarket Forced Induction Tech
Sep 12, 2013 07:07 PM
03chi-town0Z
Midwest Region
36
Feb 11, 2012 03:47 PM
ErnGotti
Apr 25, 2011 04:24 PM
cmrs2k
Feb 7, 2010 01:50 PM
