Ticking noise from 5-10mph only?! help please
Old Sep 6, 2005 | 08:53 PM
talentsearch301's Avatar
I have the same problem, took it to the dealer and at first they said it was the cv joints, but then the mech came back and said it wasnt...they dont have a clue, ...I dont have a clue either. So I really hope some EVO genius on this site can help us out!!!!!
Old Sep 6, 2005 | 10:02 PM
ChuTHIS's Avatar
Even though i feel bad that other people have a similar if not the same problem, I feel better knowing that im not the only one...
Bump for help!
Old Sep 7, 2005 | 05:58 PM
bp
Old Sep 7, 2005 | 07:24 PM
jbfoco's Avatar
i had an appoitment to get the "ticking" figured out..... I took my car in today and it didnt feel like making the noise today?
So yeah.... i don t know
Old Sep 7, 2005 | 07:29 PM
WannaRace's Avatar
Originally Posted by platinumspecv
boost selenoid ticks
Yup, just drove the car tonight and it comes on everytime I hit boost.
Old Sep 7, 2005 | 08:39 PM
ChuTHIS's Avatar
Though it could be, I dont think mine is boost related. It only doest it when i first take off from a stop...
Old Sep 8, 2005 | 01:30 PM
Same here!
has your car been in any accidents?
Since the dealer cant help me (Sheehy Mitsubishi in Waldorf Maryland...a bunch of rude retards) Im going to do another search...and then get a manual like Chiltons and try to figure this out before it gets serious and may cause an accident!
Old Sep 8, 2005 | 04:13 PM
Punisherofall's Avatar
I had the same "tick" it only happened when in 1st or 2nd when reaching full boost or when taking off from a dead stop. Try and take it to a local mechanic who can put it on a lift. My friend owns a station in CT and what he did to fix the problem was tighten the actual axel nut one rotation( or a little bit then test the car). It definitely helped! I may get it tightened a little more as now I hear it every so often where before it was everytime from a decent launch and full boost in first and second. In order to tighten the axel nut, they remove the wheel then a pin that keeps it from turning, then tighten and replace the pin. They then put the wheel back on and with any luck it will be fixed( the guy that tightened mine said he could go further, but to try this for a while). I think the problem is a slight amount of play in the axel that needs to be tightened over time. Just my 2 cents. I hope this helps you guys, the noise WAS driving me nuts when it happened all the time, now it only slightly irritates me when it happens. Oh, and it only happens maybe 1 out of 10-15 times now and I really have to listen for it, before he tightened it it happened each time. BTW my car is stock with a flash and only 7000 miles.
Stay safe,
Punisher
Old Sep 8, 2005 | 05:52 PM
ChuTHIS's Avatar
No accidents for my car *knock on wood*
Though I do think it is related to the axles. Thanks Punisher, I'll def look into that.
Old Sep 8, 2005 | 06:36 PM
thanks punisher...even though this isnt my forum...Im going to try it also...Im guessing it has to be axle, bearings or cv joints related or something in that area...I'll let you'll know after this weekend...thanks
Old Sep 8, 2005 | 07:58 PM
I hope this helps you guys, it took the mechanic who is from Saudi Arabia about 45 minutes to find the source of the noise( and he worked on Evos over in Saudi). We checked everything the Brembos, the diffs etc... Then he says let me try one more thing, that is when he tightened the nut. It was on the drivers side, and like I said I really have to try to make it make the tick noise now, but in general it never happens. I don't want to press my luck so I may leave it as is, I know how to fix the slight noise I have very infrequently now, so it will be a 5 minute fix. I think this forum is great, and I can't wait to see if this fixes your problems... let me know.
Stay safe,
Punisher
Old Sep 8, 2005 | 08:27 PM
JoizeeX's Avatar
just an idea. could it be the ABS ring, the one with lil teeth? something is rubbing against them and makes the ticking? worth checking out.
Old Sep 8, 2005 | 09:17 PM
ChuTHIS's Avatar
Awesome! ...Is there anyway you can describe in a little more detail on how to tighten this nut or where the pin is located once the wheel is off the car? Thanks!
Old Sep 8, 2005 | 09:23 PM
jbfoco's Avatar
pull the wheel off..... there is a large nut with a cotter pin through it take the pin out tighten. very important to .... MAKE SURE YOU PUT THE PIN BACK IN!!!..... you should use a new cotter pin from any hardware store will have them.
Old Sep 8, 2005 | 09:28 PM
timzcat's Avatar
IIRC Axle nut torque is somewhere around 114 ft. lbs.
So that thing needs to be TIGHT!
