New Part!!!
Old Sep 9, 2005 | 10:10 AM
  #31
Robert_K's Avatar
Thanks!!! Already read it like 3,4,5 times. I'm going w/ WhtEvo to the Auto Skills center on base (I'm active duty USAF) to use their tools and lifts.
Originally Posted by marksae
Install is not too bad if you have the right tools. Here's my install writeup:
https://www.evolutionm.net/forums/sh...d.php?t=133299
Old Sep 11, 2005 | 04:35 AM
  #32
Rushin's Avatar
how did your install go? personally, I think this is the best things i've done to my car yet.. i can pull out of any turn without understeer. i'm addicted to driving once again... big thanks to tony @ road race!!
Old Sep 11, 2005 | 05:59 AM
  #33
Robert_K's Avatar
Install became a b*tch when we needed to open the outer housing hold the diff. I think we worked that thing for about 3-4hrs before I got it to open. I'll post pics of it later on today. IT was complete destroyed!!!
Old Sep 11, 2005 | 12:51 PM
  #34
marksae's Avatar
I was able to get those ring gear bolts off w/ a breaker bar by chucking on a vice. I used the gear teeth to prevent it from rotating. But I couldn't put them back on the same way because of the gear teeth angle. It kept slipping off the vice. I ended up just using some red loctite and impact wrenching those suckers on.
5k miles, 7 autocrosses, 21 drag passes, and 1 track event later, I haven't had a problem w/ the diff or those ring gear bolts coming loose.
Old Sep 11, 2005 | 12:58 PM
  #35
Rez90's Avatar
i'm jealous...i had a quaife in my 95 GS-T and it was the best mod i ever did to the car.
Old Sep 11, 2005 | 01:05 PM
  #36
TwStDeVo's Avatar
im jealous that your putting it on, i have mine sitting here in my room, just need to find a good shop to install it, either in denver or phoenix.
Old Sep 11, 2005 | 03:34 PM
  #37
trinydex's Avatar
i have one of those! and i have a stock 04 diff too that is in perfect working condition... if anyone wants it.
Old Sep 11, 2005 | 08:50 PM
  #38
Robert_K's Avatar
marksae: Do you find the steering is a lot tighter now? Almost feels as if it doesn't have power steering unless the car is moving.
Old Sep 11, 2005 | 08:59 PM
  #39
thebluesky's Avatar
IT"S ALIVE!!!!!!!! Can't wait to see your ride in action again.
Old Sep 11, 2005 | 09:39 PM
  #40
trinydex's Avatar
this is not normal...
Old Sep 11, 2005 | 11:51 PM
  #41
marksae's Avatar
That doesn't sound normal. After I installed mine, steering felt exactly like it did before. You'd better check to make sure everything was reinstalled correctly.
Old Sep 12, 2005 | 12:19 AM
  #42
Quickshifter's Avatar
^^^^^^^^^^when drvining aggressively i found my steering to be somewhat looser rather then tighter (more oversteer) so that does not sound normal at all
Old Sep 12, 2005 | 02:19 AM
  #43
trinydex's Avatar
i'd say your axels were put back a lil incorrectly... maybe not lubed or something, cuz that's really all that coulda gone wrong right?
Old Sep 12, 2005 | 05:07 AM
  #44
Robert_K's Avatar
Power Steering fluid. I needed some power steering fluid. Its all good now.
Old Sep 12, 2005 | 05:19 AM
  #45
trinydex's Avatar
Puahaha
Rob_STI_PNW
Northwest Region
Apr 14, 2016 06:49 PM
Rob_STI_PNW
Feb 22, 2016 08:45 PM
Rob_STI_PNW
Northwest Region
Feb 22, 2016 07:54 PM
