Aps Bov ?
Old Sep 9, 2005 | 08:13 AM
MENTY's Avatar
Aps Bov ?
Just installed this bov and have an issue or two.
1. Should it be standing up straight when installed, it doesn t look like it could be installed any other way?
2. Having a hard time with the little hose that runs off the nipple. It kinks no matter the length I make it.
3. It seems like its only holding 1.3bars???? Do I need to adjust it?
New to turbo cars please help!
Old Sep 9, 2005 | 09:30 AM
RallySport Direct's Avatar
Silver Sponsor
It should look like that when installed.
Rotating it should also solve your kinked vaccum hose problem
You are not holding boost because of the kink
Go out flip it around if that doesn't fix it let me know
Ben
Old Sep 9, 2005 | 12:52 PM
TurboMR's Avatar
what about the HKS BOV....what is the best BOV for an evo 8 and has a loud sound when i let of the gas.....l
thank
Old Sep 9, 2005 | 06:20 PM
dan628's Avatar
Do you have a pic of how you have the hose routed off the BOV nipple? On the stock BOV the nipple is on the top of the valve and routed nicely to the intake manifold... According to your pic, it looks like the hose is on the bottom? Wouldnt that kink as well?
Old Sep 9, 2005 | 08:15 PM
mpevo8's Avatar
mine works perfectly fine
Old Sep 9, 2005 | 09:09 PM
Joey B's Avatar
Veteran: Air Force
Yeah, I've had mine in. And installed exactly like the pic with no problems. I honestly love this valve!!
Old Sep 9, 2005 | 09:13 PM
evo_il8's Avatar
thank
your car wont be driveable if u do that
Old Sep 10, 2005 | 07:08 AM
MENTY's Avatar
Actually had the valve installed opposite of the pic...duh...but even less boost with it this way only hitting 1bar. No kink in the hose....I am bewildered
Old Sep 10, 2005 | 07:25 AM
App420's Avatar
aps is very aggressive and unique.... no idling issues or anything to complain about.
Old Sep 10, 2005 | 07:49 AM
MENTY's Avatar
I got it!!!!! FINALLY It runs great and idles wonderful. 1 happy customer
Old Sep 10, 2005 | 09:27 AM
dan628's Avatar
Yeah but how did you route the vaccum hose since the nipple is on the bottom where stock its on the top? No one answered my question I posed before!
Old Sep 10, 2005 | 10:01 AM
djmikeymike's Avatar
thank
this is the best DV for the EVO
Old Sep 10, 2005 | 12:50 PM
MENTY's Avatar
I had it installed wrong, so I had a problem routing the hose since it only ended up being about a 2-3 inch section. Now that it is installed correctly, its about a 10 inch piece and does not pinch off.
Great valve that gives u the sound and performance most cannot.
Old Sep 10, 2005 | 03:39 PM
dan628's Avatar
I don't think you understand my question, on the stock BOV the niple for the small vacuum hose is on the top and goes up to connect to the intake or MBC if you have one. Now with this APS BOV the nipple is on the bottom. Do you just use a longer hose or what? i want to make sure before I plan on buying this valve. Thank you.
Old Sep 11, 2005 | 07:23 AM
MENTY's Avatar
Yes they supply enough hose to run it from the location it is in.
