question about knock sensor causing car to stall
Old Sep 9, 2005 | 08:18 PM
honda-guy's Avatar
just incause you guys didn't see this post about knock sensor https://www.evolutionm.net/forums/sh...4&page=2&pp=15
i did some test to similate knock and some data logging. i really want to hear some input form the experts as to what was going on when i dropped the hood and the car sputter base on my data log.
please reply in the other post so others can see.
thanks,
Old Sep 9, 2005 | 08:32 PM
awddyno's Avatar
disconnect it and try it again,
Old Sep 9, 2005 | 08:49 PM
honda-guy's Avatar
disconnect what? the datalogger? the safc?
Old Sep 9, 2005 | 08:52 PM
awddyno's Avatar
the knock sensor
Old Sep 9, 2005 | 08:59 PM
honda-guy's Avatar
the knock sensor
do you mean unbolting it from the block or just disconnect the plug? what would that do? do you think it's just a bad connection in the plug? this is a common case on evo 8, i don't think all of them could be attributed to a bad plug connect. it must be something else that's going on.
Old Sep 9, 2005 | 09:09 PM
ez's Avatar
ez
I think he means that you will isolate the cause of the stall. If the knock sensor is unplugged, and the car still stalls, then logically it is the MAS.
I am not saying that's what you should do...only clarifying the post...
Old Sep 9, 2005 | 09:15 PM
honda-guy's Avatar
ok, i know what you mean now. but wouldn't the ecu through a code if i disconnect the knock sensor? i know it does on honda engine equiped with knock sensor. unless i unbolt it from the block and leave it connected, but i don't think i'm going to try that, too much work.
Old Sep 9, 2005 | 09:20 PM
ez's Avatar
ez
That is why I included the disclaimer :> ..I don't know if it will throw a code...and how the ECU will react. My guess is...not good.
raiceboi697
Northwest Region
Dec 5, 2006 10:19 AM
Joey B
Northwest Region
Feb 3, 2006 12:09 PM
thadon84
Aug 8, 2005 11:13 PM
ozracer4
40
Apr 5, 2005 10:37 PM
dpardo
West Region
Nov 3, 2004 05:29 PM
