Bad BOV or Boost Leak????
Old Sep 9, 2005 | 10:01 PM
Stop&TurnFreak's Avatar
I have tightened all the fittings, and double-checked all the joints. I can turn the boost down to 1.3, and it will hold solid, dropping only to about 1.2 at 7K. If I turn the boost up to 1.45, then it drops off after 6500, and you can hear it a rush of air up front, like it is blowing off, and it drops to 1.1Bar or lower, and then holds there.
If it is a leak, I have no idea how, I have the fittings so tight now, they are almost eating through the hoses. (however they are not).
Thoughts?
Old Sep 10, 2005 | 05:30 AM
matt55's Avatar
Just b/c the clamps are tight dont mean they cant leak . do a boost leak test and get it over with . Then you can come back here and tell us that xxx bov sucks or woops that lower ic pipe is a pian it the as$ . check this out
https://www.evolutionm.net/forums/sh...d.php?t=148479
