Boost problem fix!!!!
Old Sep 11, 2005 | 06:55 PM
Boricua21's Avatar
After trouble shooting for days finally found the problems it was a few leaks, but the real problem was the line that goes from the outlet pipe to the T connector with the waste gate up to the solenoid because I removed the restrictor pill that goes in that line and I wasn’t passing 12psi I reuse the other one and now I’m up to 15psi be sure not to make the same mistake.
