negative factors with short shifter?
Old Sep 13, 2005 | 09:39 PM
essjEVO's Avatar
is there any bad things about having a short shifter? thanks
Old Sep 13, 2005 | 09:40 PM
Curt@MrLed's Avatar
Former Vendor
you might have to use a little more effort to shift..
Old Sep 13, 2005 | 09:52 PM
essjEVO's Avatar
but is there any chances that it MIGHT affect the synchros?
Old Sep 13, 2005 | 09:56 PM
Curt@MrLed's Avatar
Former Vendor
no.. installing a short shifter is the same as cutting your stock shifter shorter... now if by some odd chance you installed it incorrectly you might screw up the shifting pattern, if you somehow screw up puting a short shifter in you better let somone else work on the car... cause its pretty hard to mess up the install..
Old Sep 13, 2005 | 09:58 PM
ez's Avatar
ez
No...unless it alters your ability to shift properly or match revs. However, an improperly adjusted shifter *could* affect fork/drum engagement...improper engagement could affect synchros at some point.
Old Sep 13, 2005 | 09:59 PM
ez's Avatar
ez
Sorry Farmer...I type sloooow.
Old Sep 13, 2005 | 10:00 PM
Curt@MrLed's Avatar
Former Vendor
so do i.. but for some odd reason i am doin good tonight.. edit.. was doin good..
r3z0nate
Midwest Region
Aug 1, 2007 06:42 PM
Evolelm
Dec 27, 2006 02:02 PM
dcaudio
South Region
Oct 24, 2005 11:38 PM
EvoDaWayToGo
Apr 8, 2003 07:27 AM
