CEL w/ Ultimate Racing test pipe?
Old Sep 14, 2005 | 02:31 PM
EVIL_EVO_VIII's Avatar
Angry CEL w/ Ultimate Racing test pipe?
I have an Ultimate Racing test pipe that i was using on my 03. I got a CEL like maybe 2 times for almost a year on my 03. I have put it on my 05 and within 1k miles i have gotten the CEL 3 times already, wtf? Its installed properly and everything. Ive had to reset the Ecu 3 times and i dont know why it keeps coming on. I pulled the code and it said failed circuit 02 sensor #2 which is the cat. What can i do? Should i call UR?
Old Sep 14, 2005 | 02:34 PM
Evo8dude's Avatar
I also have the UR 3 inch test pipe, i didnt even bother putting in the CEL fix thing because i knew it would come on anyway. i dont really mind the CEL in my cluster but if it bothers you id say call them and see what they can do
Old Sep 14, 2005 | 02:36 PM
The thing is that they guarantee NO CEL!!
Old Sep 14, 2005 | 04:41 PM
Ultimate CC's Avatar
If it is really bothering you do a search for "spark plug fouler" and you will find a very easy mod to take care of ur CEL. I have a 05 with a rsr dp which deletes teh cat and after about 300 miles I would get a CEL.
Dan
Old Sep 14, 2005 | 05:00 PM
titaniumkingpin's Avatar
thats a suprised.... ive had my UR test pipe for a few years now and never got a CEL.
Is it possible that your 02 is bad?
and did you install the pipe backwards?
the bung should be facing the front of the car.
Old Sep 14, 2005 | 05:56 PM
ez's Avatar
ez
The solution is simple. Remove the rear O2 and put in an O2 simulator.
Such as:
http://www.vividracing.com/catalog/p...oducts_id/6530
Old Sep 14, 2005 | 08:02 PM
Its a new car so i know the 02 sensor isnt bad. The bung is facing towards the front to the passenger side. I had it on my 03 before and i never had this problem, well i did but it was 2 times in almost a whole year.
Old Sep 14, 2005 | 08:11 PM
Im gonna contact Ultimate Racing about it to see what they have to say
Old Sep 14, 2005 | 08:12 PM
WrX Kila's Avatar
I have the UR test pipe, and I NEVER got a CEL light.
Old Sep 14, 2005 | 08:45 PM
ez's Avatar
ez
I know I mentioned the O2 sim as the solution...
But just to add to the responses, I run the rear factory O2 in a Magnaflow 3" test pipe with no O2 sim and I have no CEL.
Old Sep 15, 2005 | 05:43 PM
Z1 Performance's Avatar
I'd check the wires...99% of the time it is due to improper install.
I have never had one of them cause a CEL
Old Sep 15, 2005 | 09:40 PM
Its installed correctly, and i havent messed with the wires. All i did was plug and play thats it!! I reset it again and it hasnt come back on yet. Lets see how long it lasts
Old Sep 16, 2005 | 01:13 AM
nj1266's Avatar
Perhaps you need to space the O2 sensor further from the exhaust stream. I just got the UR HFC in the mail and it came with the cel fix. I noticed that the cel fix they send is shorter than the 4002 anti-fouler plugs that you attach together to space the O2 sensor from the exhaust stream. A lot of people who use one anti-fouler plug rather than two do get cel lights. Try useing two instead and see what happens. It is possible that the 05 EVO is more sensitive to HFC/TP and you need to space the O2 sensor further from the exhaust stream.
I will tell you how my HFC turns out when I install it tomorrow.
Old Sep 16, 2005 | 01:26 AM
Curt@MrLed's Avatar
Former Vendor
https://www.evolutionm.net/forums/sh...12#post1505712
i have no cat, or muffler on my now 05, which came off the 03, and no cel...hehe.. but i have the fouler in case it does..
Old Sep 16, 2005 | 03:04 AM
Evil EV0's Avatar
Weird...I have over 20K miles on mine and no CEL.
