MBT - maximum brake torque timing
Old Sep 16, 2005 | 05:43 PM
SlowCar's Avatar
Can someone please explain what MBT is? Is it measured on a dyno?
Old Sep 16, 2005 | 07:49 PM
ez76's Avatar
It's the minimum ignition timing advance needed to obtain the maximum torque from the engine at a given load, RPM, air/fuel ratio, and temperature.
You aren't always going to be able to dial in this much timing, e.g. because of octane limitation.
Old Sep 16, 2005 | 11:36 PM
SlowCar's Avatar
So how is this value measured, on a dyno? Can it be done on a road tune??
Old Sep 17, 2005 | 08:53 PM
SlowCar's Avatar
bump
Old Sep 18, 2005 | 12:53 AM
Mercenary3's Avatar
The best way to do it is on a dyno...a variable load dyno. You can get it in the ballpark on a raod tune, but youre never going to be as accurate.
darwin_evo
E85 / Ethanol
10
Jul 10, 2017 07:57 AM
hediki12
May 2, 2010 07:08 PM
R/TErnie
Oct 7, 2009 11:33 AM
jcsbanks
Mar 18, 2009 07:12 AM
mbt2002
Oct 17, 2003 07:14 AM
