HKS CAMS 280 vs TOMEI 280
Old Sep 18, 2005 | 01:57 PM
Yaroslav's Avatar
Question HKS CAMS 280 vs TOMEI 280
Is anybody has experience with TOMEI 280?
and is it worth to change my HKS 280 on TOMEI?
Help please
Old Sep 18, 2005 | 01:59 PM
sayanara's Avatar
Good question, wondering the same. Tomei does have significantly more lift.
Old Sep 18, 2005 | 02:00 PM
KTT's Avatar
KTT
I am not sure matters with 745 hp .. that evo sounds beefy
Old Sep 18, 2005 | 02:03 PM
Yaroslav's Avatar
Man it`s power not from Dyno
Measuerd by WRC meter "RACE TECHNOLOGY"
Still can`t catch R1, but the same as R6 (exhaust+power commander)
Old Sep 18, 2005 | 02:14 PM
rlazer5000's Avatar
I think the Tomei cams have a higher lift than the HKS cams. The HKS cams are somewhere in the high 10s for lift, where the Tomeis are 11.5. I've heard the Tomeis will make more HP than HKS, but I can't verify that. Someone with Tomei cams should be able to answer that one.
Old Sep 25, 2005 | 02:55 PM
feldguy's Avatar
Higher lift, bud. 11.5 versus 10.2. Ive heard that these cams are sick when used with a nice big turbo, ported head and a beefy valvetrain. One guy I knew used them in a stroker, rev limit at 8300rpm on a 2.3 with a GT35R. He switched from HKS with pretty decent results in power production, but the biggest downfall was the lack of experience that people have gotten with the Tomei's versus the HKS', as they are much more widely used.
Old Sep 25, 2005 | 03:04 PM
Yaroslav's Avatar
Question
THANKS FOR ANSWER MAN,CAN YOU GET KNOW MORE INFO ABOUT THESE CAMS?
LOW END AND HIGH END POWER WITH STROKER 2.3+GT35+EVERYTHING
THANKS!
Old Sep 25, 2005 | 03:50 PM
feldguy's Avatar
No problem , bro. I'll keep digging, and post here. You do the same.
I'd have to say the only person using these cams on huge turbo evos, was George from Boost solutions. That guy was a $ick, didn't know how to tune either.
It just seems obvious that the 11.5 mm lift versus the 10.2 will add power capacity, but I'd plan on the same results and more difficulty tuning, especially the aggressiveness of the idle charachteristics. Im gonna go for them anyways, along with the valvesprings and cam gears, and whatever Dave Buschur uses as far as retainers and valves in my hopefully soon to be built heads. I might just go for the HKS 280's if Dave feels that strongly about the advantages of them. I'll let you know.
Old Sep 25, 2005 | 03:54 PM
Yaroslav's Avatar
Exclamation
Old Sep 25, 2005 | 05:55 PM
jmartinez1170's Avatar
i would get the tomei if i had the money over my hks 280's all day. u just cant buy the cams u need the springs as well but the u need the retaniers as well. if you want to get the most power out the car and thouse cams u need a stage 3 or higher head port with the spring and retaniers with this if your car can handel 10 grand rev lim. on it vs the hks which is 9200 rev lim. also u would need a reflash or a new ecu if you call tomei then would send u a new ecu just give them a part break down off your car along with a data log sheet they will set u up nicely but the down fall of all this it cost a few grand to get this done but i must say tomei is one of the best. good luck man.
Old Sep 25, 2005 | 07:16 PM
feldguy's Avatar
martinez, Im planning on using all of that plus a standalone EMS. In due time, in due time
Old Sep 26, 2005 | 12:45 AM
let me know man when u get this done i want to see numbers they should be off the charts. u got my respect man good luck.
Old Sep 26, 2005 | 12:53 AM
evodrifter's Avatar
would they be harder to street cause of the lift?
Old Sep 26, 2005 | 12:59 PM
RnR Racing's Avatar
We have been using these cams in our car for over a year with our 2.4 and reving to 9K no problem.
Old Oct 7, 2005 | 07:33 PM
feldguy's Avatar
You've been using tomei procam, 280's in the RnR Shop car? Whats the idle like? Any videos of it? Im just curious.
