ams turboback
Old Sep 19, 2005 | 02:41 PM
EvOwanKenobi08's Avatar
ams turboback
alright so i just got it in the mail and i was just wondering if anyone knew how to install it cuz im not sure i got all the parts i got 5 bolts for the cat back and 2 flanges for it but nothin else for the downpipe or test pipe did i get everything or am i missing some stuff
Old Sep 19, 2005 | 03:00 PM
scherejs's Avatar
well the cat-back section needs 3 bolts to go from the test pipe to the midpipe and then another 3 bolts that goes from the midpipe to the muffler section in the rear. you will reuse the two bolts that bolt the downpipe to the o2 housing. i can't remember if the downpipe is a slip-fit to the test pipe or not. i'd give them a call if i were you.
Old Sep 19, 2005 | 06:11 PM
does anyone else have anything to add or say?
Old Sep 19, 2005 | 08:34 PM
Compjoc's Avatar
If it's the same version exhaust that I bought from them 1 1/2 years ago then you should have 9 bolts and 3 gaskets.
Old Sep 20, 2005 | 06:37 AM
coastal96's Avatar
I just installed mine a couple weeks ago on my 05 and Compjoc is correct. You will need 3 bolts/nuts for the DP to test pipe . . . 3 bolts/nuts for the test pipe to the mid-section . . . and 3 bolts/nuts for the mid-section to the axle-back. You obviously need 3 gaskets for those same connections.
MTP2
Canadian Forum
Aug 9, 2009 11:32 AM
SAtown EVOx
Evo X How Tos / Installations
Jul 8, 2008 01:33 PM
Kapalmuks_EVO
16
Feb 17, 2007 06:25 PM
Lancer_Man7
12
Nov 18, 2003 11:31 AM
aZnLaNcEr
West Region
10
Mar 26, 2003 12:25 PM
