Highest boost levels with stock turbo
Old Sep 21, 2005 | 04:41 PM
warp9's Avatar
How are we to go about getting boost higher than 24-25 psi...?Is there an acuater trick or replacement? Thanks
Old Sep 21, 2005 | 04:47 PM
superman105's Avatar
very easy
if you take the boost line off your wastegate you can get 29 psi !
Old Sep 21, 2005 | 04:53 PM
warp9's Avatar
Thats one way!............more please
Old Sep 21, 2005 | 05:52 PM
mooreboost's Avatar
The Forge actuator should work.
I know it holds 25psi for sure.
Old Sep 21, 2005 | 06:05 PM
warp9's Avatar
So you guys think that 25psi is the the turbos actual limit?.........We nee the 11 sec guys to shed some light
Old Sep 21, 2005 | 06:44 PM
EvoDan2004's Avatar
i run 63 psi on my stock turbo. it hold great. and im stock. o and dreaming
Old Sep 21, 2005 | 06:50 PM
cyberninja's Avatar
of you are going to need a flash to achieve this. anything higher than 22 1/2 psi on 93 and your car will hit a boost cut/fuel cut on stock ecu.
Old Sep 21, 2005 | 07:03 PM
Jin4g63's Avatar
What is the stock turbo psi?
Old Sep 21, 2005 | 07:04 PM
EvoDan2004's Avatar
19
Old Sep 21, 2005 | 07:11 PM
Curt@MrLed's Avatar
Former Vendor
its effiecent to around 22 psi..
Old Sep 21, 2005 | 07:44 PM
TURBODAWG's Avatar
If you get a BOV that wont leak and get an ECU flash to get rid of boost cut. And get a MBC and turn it up, the boost will go to 33 or 34 psi...... The only BOV I know for sure that wont leak is a HKS SSBOV. Also, if it wont go that high, then you need to pressure test your system for leaks. Once I sold the JDM MR BOV that I had, fixed all my boost leaks, and put on the HKS SSBOV on my old car. The boost went from 26 or 27 psi maximum to 33 to 34 psi. These were primarily spikes that would maintain until about 5500 RPM then start falling off to 22 psi up top.
My .02!!!! Oh yeah, your car must be tuned properly or you engine will go BOOOM with that much boost and you better have some 110 octane gas.
Brian
Old Sep 21, 2005 | 08:25 PM
ct9a gsr's Avatar
boost controller + flashed ECU or piggyback/stand-alone + C16 or alky/meth injection = spikes upto 33psi/34psi
29psi~30psi seems like a good level to keep it at...
Old Sep 21, 2005 | 10:16 PM
Doogie Howser's Avatar
What kind of bov/ dv?
Old Sep 22, 2005 | 02:08 AM
CMB's Avatar
CMB
Lightbulb
I have the supporting mods, but it only went to 24-25 psi........i think it was 1G blowoff valve that comes with my kit that was holding things back. I think the Forge replacement does the trick
Old Sep 22, 2005 | 02:12 AM
warp9's Avatar
You are dead on, i think that might be the problem.......When i go to Pruven for the cam install i will swap it out....
