clutch install!!!
Old Sep 21, 2005 | 05:37 PM
BMTEVO8's Avatar
clutch install!!!
i have an 03 evo and i am changing out the clutch in it, the shop that is doing is a freind of my dads so i am getting a good deal. now here is were it goes south, they are in the process of changing the flywheel and get to the pressure plate to find out that it is welded to the input shaft, so my question is has this happened to anyone else? oh and on the top of all this i am evacuating form hurricane rita with my babay still in the shop up on a lift!!! its going to be a bad couple of days.
Old Sep 21, 2005 | 05:57 PM
ez's Avatar
ez
Man I would forget about the flywheel for now and lower the car to the ground. Cover it with a plastic tarp, plywood, and anything else you can get to protect it from falling debris...
Old Sep 21, 2005 | 09:49 PM
MrMejia's Avatar
wow man I'll be praying for you
Old Sep 21, 2005 | 09:55 PM
evo_rc's Avatar
hope your babe wont get hurt....
Old Sep 22, 2005 | 04:05 AM
Evil_1's Avatar
Are you saying they can't get the tranny off cause the shaft is stuck at the flywheel? There is a spring in there and you'll need to stick a long flat head and wedge it b/w the throw out bearing and spring and pop it lose. What clutch did you get?
Old Sep 22, 2005 | 12:10 PM
ACTman's Avatar
I think Evil 1 is right. If they are not familiar with pull type clutches, they would think the disc is stuck, when actually they need to release the bearing from the pressure plate before the trans will come off.
Old Sep 22, 2005 | 12:30 PM
GOKOU's Avatar
Or you could be praying that you can get an 05 EVO
Old Sep 22, 2005 | 03:16 PM
superz's Avatar
I agree, I have yet to see an Evo with a welded disc to the input shaft. At the same time they said that the pressure plate is welded to the input shaft. This makes no sense since the pressure plate doesnt make contact with the input shaft, the throw out bearing makes contact with the pressure plate. They are having trouble separating the throw out bearing off the pressure plate. They can sometimes be a PITA.
Old Sep 22, 2005 | 10:47 PM
awddyno's Avatar
sucks when you let a shop work on newer cars. pull type clutch system has been around for a while but if your tech hasn't seen one before, he will have a hell of a time trying to get that off. tell him to bolt the trans back on to the block and read how to disengage the throw out bearing. Hopefully he hasn't ruined it to a point that he has to unbolt the pressure plate to get the trans off.
Old Sep 26, 2005 | 02:01 PM
BMTEVO8's Avatar
yea i think that he is just new to a pull type clutch and thinks that it is welded on there, by the way the car is alrigt i hope, since now i am stuck in arkansas with relatives. but will find out when i get back.
