TSB for tranny rattle, where is it?
Old Sep 21, 2005 | 06:26 PM
silvrevo's Avatar
I cant find the tsb for the reverse idel arm. I think I have this going on. When the ac is on and im stopped with clutch out I hear this rattling, like metal on metal.
Then I push the clutch in and it goes away. From what I have read this sounds like the Idel arm. And now I would like to be pointed in the right direction to find that TSB. I cant find Sheit on here, either its me or the search button.
Thanks in advance.
Old Sep 22, 2005 | 06:47 AM
Alacris's Avatar
I had the same symptoms. They replaced the reverse idler assembly and it did nothing. Still rattles.
I did some very thorough tests of when it rattles and when it does not. I'm 90% sure it is the input shaft of the transmission (either the shaft or the bearings) rattling around.
Seems a lot of people have this noise, so I wouldn't worry too much about it, but just be forewarned, that TSB for the reverse idler might not fix it.
AC
Old Sep 22, 2005 | 06:49 AM
Curt@MrLed's Avatar
Former Vendor
every evo i have owned or seen has a slight rattle with the a/c on..
Old Sep 22, 2005 | 07:03 AM
EvilDylan's Avatar
that is the throw out bearing that is making the rattling noise. Almost all TO bearings rattle after a few k miles.
Old Sep 22, 2005 | 07:07 AM
Curt@MrLed's Avatar
Former Vendor
they really only make that noise though when there is a good load on the motor at an idle.... hence the a/c on.. i forgot about that.. thanks..
Old Sep 22, 2005 | 09:12 AM
silvrevo's Avatar
So whats the deal? Let it be,,, is it going to ruin my tranny or clutch?just have service make a note of it?
Also I have 34k on the clock. Stock clutch.
And can someone post a link to that tsb for the idel arm.
Thanks again.
Old Sep 22, 2005 | 09:36 AM
Alacris's Avatar
Sorry, don't have the TSB (and it wasn't on my receipt, at least not that I could find). Search the forums, I think someone posted a link to NTSB or NHTSA website that has a search for recalls and TSB's.
Oh, and it is probably okay as is. At 34k, you may want to look into a new clutch, but if it isn't slipping, chattering, or otherwise misbehaving -- you are probably fine.
good luck,
AC
Old Sep 22, 2005 | 11:42 AM
Steve@Evolution's Avatar
I have the rattle but it seems normal so far.
Steve - Evolution
703-961-9090
Old Sep 22, 2005 | 04:22 PM
SHORACETEAM's Avatar
I have a copy of TSB-05-22-001 that covers the tranny rattle. If you would like a copy, I would be glad to email it to you.
Old Sep 28, 2005 | 01:15 PM
F&I-EVO's Avatar
Could you post it here?
Old Sep 28, 2005 | 01:16 PM
nastyevo8's Avatar
do you have a twin or triple plate clutch or still stock.
Old Sep 28, 2005 | 01:42 PM
F&I-EVO's Avatar
stock
Old Nov 9, 2005 | 08:06 PM
93civEJ1's Avatar
anyone have this?
Old Nov 9, 2005 | 08:12 PM
dubbleugly01's Avatar
my tranny has rattled with the a/c on, since day one. It's worse the hotter the transmission is also. I'm now at 41k miles, and it still sounds the same. I've heard 3 other newer EVO's in Houston make the same noise. Seems to be common, if not all together normal.
Old Nov 9, 2005 | 08:14 PM
93civEJ1's Avatar
nah, man...my car is in the shop now at 53k miles, not going to be warrantied, and my input shaft seal is shot they think...im wondering if the TSB for input shaft/bearings may be something i need to show them.
