Boost Problems!
Old Sep 27, 2005 | 03:45 PM
bigboybusa's Avatar
Originally Posted by SHORACETEAM
You might want to try a different boost gauge. Where do you have your boost gauge hooked up at?
I am using the mitsubishi gauge package.
Old Sep 27, 2005 | 03:46 PM
bigboybusa's Avatar
Originally Posted by titaniumkingpin
try this.....
take your K&N intake out, and leave the MBC in.
I was thinking of trying that. thanks
Old Oct 16, 2005 | 07:22 AM
bigboybusa's Avatar
PROBLEM SOLVED!
I did some investigating, switching out parts here and there. Test driving other Evos which have similar setups.
I 1st took off the filter, run the car with out 1, and noticed that it still hit boost cut but the check engine light didn't go on and I was able to get the boost upto 1.3 kgcm2. Then I put back the air filter and took off the piping, and disconnected the battery to reset the ecu. I was able to crank up the boost to 1.4kgcm2 without any problems!!! I am still using the K&N air filter that came with the typhoon kit, but I have ordered a Apexi kit and a HKS kit to try out.
Conclusion, I am very disappointed with the typhoon intake and would recommend to anyone would is going to mod their Evo more than the usual intake, exhaust, etc... To not get this!
svt_lightning01
Mar 31, 2011 01:08 PM
tim85851
23
Sep 24, 2009 10:00 AM
stimpy
12
Aug 23, 2007 10:04 PM
2literturbos
Jun 28, 2004 10:08 AM
twkwan
12
Jul 4, 2003 05:44 AM
