DP leak....
Old Sep 26, 2005 | 06:00 AM
GOKOU's Avatar
DP leak....
As I suspected I have a minor leak where the BR downpipe meets the 02 housing. I can hear tapping noise during cold start-up and the idle fluctuates during cold start-up and become steady once the car warms up. Is there a gasket that I can put in between to stop the leak? Not sure if I can just tighen up the DP bolts. The leak happen after a clutch install. Not sure what the guy who install my clutch did.
Also anyone know whether that kind of leak will effect my custom tune?
Thanks.
Old Sep 26, 2005 | 08:13 AM
Cannonballer's Avatar
Leaks after the turbo are usually nothing more than an annoyance. Your hi-flo cait is a little more high flow if you will.
Old Sep 26, 2005 | 08:18 AM
Thegame's Avatar
You could try some of that gasket maker stuff. It's usually a hit or miss with that though.
Old Sep 26, 2005 | 08:20 AM
kmcconn9's Avatar
I would take the dp off and retighten each bolt with the same pattern. 1 full turn, then tighten the other bolt, i full turn etc..
Old Sep 26, 2005 | 08:21 AM
GOKOU's Avatar
Hmm I hope you're right. Odd thing is that I think and the car feels like performance was effected. Maybe I'm just paranoid. I have a straight pipe.
Old Sep 26, 2005 | 09:01 AM
PPI's Avatar
PPI
your paranoid
Old Sep 26, 2005 | 11:06 AM
GOKOU's Avatar
Originally Posted by manOfaith
your paranoid
Maybe
Can someone explain why a leak after the turbo will not effect performance?? Doesn't this effect the back pressure? Don't know so just asking.
Thanks.
Old Sep 27, 2005 | 01:45 PM
GOKOU's Avatar
Can someone tell me I'm right or wrong about a DP leak?
Old Sep 27, 2005 | 01:59 PM
EVO_8's Avatar
Originally Posted by GOKOU
Maybe
Thanks.
I don't think it will affect performance, as you said it's after the turbo, so the exhaust gas did it's job and can leave the system. The back pressure - by installing 3" exhaust we're trying to keep it at minimum, so I don't think any additional leakage will be bad.
kevzxvii
11
Sep 28, 2023 10:02 AM
Omar Ramos
Jan 29, 2017 09:43 AM
Lancerfry30
Aug 6, 2016 12:00 PM
moogatwo
Jul 7, 2015 09:33 AM
GOKOU
May 20, 2005 12:14 PM
