weird POP from my motor
Old Sep 29, 2005 | 02:41 AM
wikdwhiterabbit's Avatar
Originally Posted by Rcebowl
and would a fuel pump be something that you would suggest before my reflash??
Not necessary at this point + flash doesn't compensate for fuel pump so you can put it on any time.
Old Sep 29, 2005 | 02:45 AM
Rcebowl's Avatar
really?! ... on dynoflash it says.. after a fuel pump.. it needs a retune .. no?
CoolGuyWes's Avatar
I would always suggest a fuel pump if you plan on going much higher than stock HP. and you need to tune after that so yeah doing it first would be a good idea. And it is only like $100 for the walboro and I believe installation is like 40... At least that’s what my shop charged. Pretty easy though could put it in yourself with basic knowledge... I’m just busy so I had the shop do it. And yes the weather affects these cars. Try resetting you ecu and see if that helps.
Old Sep 29, 2005 | 02:46 AM
CoolGuyWes's Avatar
yes... without a retune your car runs much richer after a fuel pump upgrade.
Old Sep 29, 2005 | 02:48 AM
EVOGOD21's Avatar
YES make sure you get 255walbro fuel pump before reflashing you ecu i got my full pump the same day i got my ecu back, boy if i was a happy boy! also make sure you have a 1/4 of gas or ealse you gonna have fun with the gasafter that you should drive like 5 milles before you start going crazy,when i was back fireing i was back fireing when i was down shifting and same happend to me just like coolguywes!
Old Sep 29, 2005 | 02:53 AM
CoolGuyWes's Avatar
I'm going to bed... if there is anything else that I can help you with feel free to pm... And I will reply in the morning... other wise it was nice talking to you and I hope I was somewhat of a help.
Old Sep 29, 2005 | 03:05 AM
EvoRicer's Avatar
Maybe one of ur vacuum lines came loose or ur spark plugs or wires went bad? I had fuel cut with my 03 too...had the nology wires which were crap. switched back to stock wires and plugs. Also had a boost leak. My car is fine now.
Old Sep 29, 2005 | 06:54 AM
evo0486t's Avatar
ive got that same issue .. but only thing is i ve got the stock box, manual bc, fuel pump, an d3 inch exaust.. especially when its cool outside i get that pop a lot right after letting of the gas on boost... and my car is not flased or nuttin.. im guessin its because of the weather n plus i ve been driving on it everyday for like 5 months already.. so i guess ur fine....
Old Sep 29, 2005 | 07:08 AM
gsujeff55's Avatar
ok, how much boost were you running? what boost gauge?
sounds to me like you are hitting fuel cut because your boost went up with the more dense air. it can go up 2-3psi when temps go from 90s to 60s.
Old Sep 29, 2005 | 08:06 AM
Creamo3's Avatar
+1 sounds like fuel cut to me also
Old Sep 29, 2005 | 08:22 AM
JeffR116's Avatar
Yep, sounds like fuel cut to me as well. Every 11 degrees F decrease gives you a 1 percent increase in air density. The colder air most definitely made a difference, especially without you running a tune.
Old Sep 29, 2005 | 08:41 AM
Rcebowl's Avatar
but i was only hitting 20 psi... maybe 20.5 ... with a VDO guauge ... i really dont think that's what it was..
i think it's just going to be a retune issue... and try that out
Old Sep 29, 2005 | 08:54 AM
gsujeff55's Avatar
i can't imagine your tune going south and making your car backfire at WOT. in fact, its nearly impossible.
backfiring after letting out of the throttle is sort of a 'running rich' issue, but backfiring during wot is not.
Old Sep 29, 2005 | 09:59 AM
Rcebowl's Avatar
well.... i havent tuned yet...
*it did it again this morning
and it's not when i letting off the gas... .. it's jus when i hit WOT .... at about 5k to 6.5k (hitting about 20 PSI again... 20 to 20.5 psi) rpms... my car like POPS ... then i hit fuel cut... .and this morning when i hit it... it tripped an engine code.. which really makes me worry
after class i'm going to take my car to autozone to find out what code i tripped...
none of the mod i did could really make me do this could it??? let me know what you think??
i'm going to turn down my boost
Old Sep 29, 2005 | 10:20 AM
GinuwineEvo8's Avatar
Yeah fuel cut for sure definitley because of the weather .. when its hot I run 19psi to redline ... but when the weather gets colder @ night I CAN get fuel cut in 5th gear and I'd have to turn it down ... it should only happen in 4th and 5th though ..
Turn the boost down -save your gas anyway its not like your racing plus your still not tuned ;D
