Clutch Viagra?
Old Oct 3, 2005 | 01:14 AM
Big Shooter's Avatar
Clutch Viagra?
well i finished my clutch install a few min ago. i went to bleed my slave cyl. cause the clutch was sloppy. after bleeding it twice it felt ok. but after doing a third bleed my clutch pedal has NO resistance what so ever. it will go to the floor and stay there. if you pull it it will pop back out. but it can be pushed to the floor with a pinky finger. more bleeding led to nothing. do i need to add fluid? is so what kind and where? if not what else could be wrong? anything else i need to be on the lookout for? could i ask more annoying questions?
Old Oct 3, 2005 | 01:44 AM
Evo_Jay's Avatar
search
Old Oct 3, 2005 | 05:12 AM
search for what? why is my clutch floppy? reasons for floppy clutch?
Old Oct 3, 2005 | 05:18 AM
jude's Avatar
It's obvious that you either bled it wrong or there is a leak somewhere. Keep the fluid level at or above the neck in the master cylinder. check your banjo connections also to make sure they're tight. If everything seems to be in order you may have a bad slave cylinder.
Old Oct 3, 2005 | 05:21 AM
if there was a leak, i would i find fluid and i havent found any fluid. could i have ruined the slave cylinder by messing around with it like this. it was fine before the install.
Old Oct 3, 2005 | 05:25 AM
jude's Avatar
I highly doubt it. If you can change a clutch you should be able to figure this out. Did you remove the clutch line?
Old Oct 3, 2005 | 08:47 AM
voidhawk's Avatar
I'd guess you have air in your lines, probably let the fluid level drop below the min level on your last bleed and didn't notice you were sucking air. Do another bleed with a second person to help you watch fluid levels.
Old Oct 3, 2005 | 09:28 PM
all yes thank you wise men. i just had to fill the res. more and pump alot more and i got her going great act street disk feels good. how many miles is the break in?
Old Oct 3, 2005 | 09:53 PM
asasin79's Avatar
happened to me...but i had a blown seal in my slave cylinder. that was pretty obvious.
Old Oct 4, 2005 | 03:12 AM
BaLListic_EVO's Avatar
cha that **** happened to me had it all bled then ran it outta fluid... that side is kinda hard to see...
Old Oct 5, 2005 | 10:35 AM
inarut's Avatar
clutch?
I had that happen to me and it was the slave.I replaced it and good as new.
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
jaycee842
11
May 27, 2016 06:35 AM
moey124
May 4, 2016 12:42 PM
idriveanevo
Feb 28, 2009 02:39 AM
SpunEvoIX
Jan 12, 2009 10:00 PM
