HIGHEST BOOST>>>>>>>>>
Old Oct 5, 2005 | 04:37 PM
  #31
gsujeff55's Avatar
Originally Posted by dEdiYT11
28 on 91 pump gas, 32 on 110 Race Gas
HKS 3037s
you forget to mention you are spaying alky, or are you trying to see how far you can sling a piston?
Old Oct 5, 2005 | 04:43 PM
  #32
dsm95hybrid's Avatar
HKS 3037s
Absolutely irresponsible post. Do not attempt high boost on 91oct or even 93 for that matter. Someone failed to mention that meth @ 115oct must be sprayed along with this pump gas as not to destroy your motor.
Old Oct 5, 2005 | 04:50 PM
  #33
warp9's Avatar
Originally Posted by dsm95hybrid
31.3psi no issues, stock turbo.
whats the secret to letting the stock turbo go this High?
Old Oct 5, 2005 | 04:54 PM
  #34
Free up your intake and exhaust. O2 housing, Forge wastegate, MBC, high octane or meth injection, wideband O2 meter/logging system and as much datalogging equipment as possible to keep it safe. The more info the better.
Old Oct 5, 2005 | 06:13 PM
  #35
warp9's Avatar
So the forge wastegate is worth it?...dont forget a good BOV too.
Old Oct 6, 2005 | 01:38 PM
  #36
Kronik's Avatar
oops...typo ...sorry warr
Old Oct 6, 2005 | 01:43 PM
  #37
Soon2BEVO's Avatar
05 EVO - 22psi on 93-94. Usually 94! When my car was at Pruven I was getting 0 knock count @ 22psi. Car feels strong! Al said that he seemed to be able to get away with 22psi on pump with the 2005s more so than the 03-04s due to the larger turbine housing.
Occasionaly, I throw in a couple gallons of 112 leaded and turn it up to 24! Seldom though..
Old Oct 6, 2005 | 01:51 PM
  #38
EVIL_EV0's Avatar
You guys running over 22 PSI .....how are you not hitting MAF cut?
Old Oct 6, 2005 | 02:10 PM
  #39
Soon2BEVO's Avatar
Ive never heard of MAF cut. Do you mean fuel cut? I never had any issues, of course I only ran 22psi when I got the car reflashed by Dynoflash. Before that my car was 19psi.
Old Oct 6, 2005 | 03:50 PM
  #40
Juiced's Avatar
Not For long.....
Old Oct 8, 2005 | 07:21 AM
  #41
EVIL_EV0's Avatar
No I mean MAF cut because thats really what it is.....its a fuel cut that happens because your MAF reading is too high and the ECU thinks the WG soliniod is broken.
Old Oct 8, 2005 | 08:32 AM
  #42
Soon2BEVO's Avatar
Oh. Ive never even heard of that!
Old Nov 26, 2005 | 10:34 PM
  #43
EVO-8-Nate's Avatar
I am running 26psi on 93 octane and 100%Meth but it only gets that high in 4th gear. The stock 9.8t turbo doesn't have enough of a load for me to hit full boost in those gears.
Before on 93 octane pump gas I was hitting 21.9psi.
-Nate
Old Nov 27, 2005 | 12:58 AM
  #44
pjsevo8's Avatar
I have hit 33psi with alcohol injection. It likes to taper down tho lol
Old Nov 27, 2005 | 10:41 AM
  #45
Mr. Stock's Avatar
23psi tapering to 20 on 93 octane. A/F ratios were in the 9's on my last dyno. Having her tuned on the 10th along with a Forge actuator installation.
