Timimg Belt Issues, wont line up
I have never heard or seem it before either. When you try to lign up all four timing marks either the intake or exhaust cam is a 1/2 tooth off. If it was a hole tooth of I would just move it one way or the other to fix it. You use all 4 marks that is why they are there, and all the writeups show using a ruler to line all 4 up. Are the same sprockets different could the be swapped that is all I can think of.
Check this out. http://www.vfaq.com/mods/timingbelt-2G.html
Originally Posted by timzcat
Give me 5 minute and I will have an answer for you. I want to look at the procedure in the DSM manual and compare it to the Evo procedure.
The EVO and a DSM are the same except the timing marks on the evo cam gears on the evo are a PITA to line up while maintaining it in timing. The DSM is easy compared to the evo to line up.
I have the original service manual pages for you with the right procedure. PM me an email address and I will send it to you. It's too big to attach here.
This will get the marks as close as you will get them. The exhaust will be off by a little bit, though.
Originally Posted by VTECH8TR
Timzcat,
anthonypazsd
135
Apr 2, 2026 12:56 PM
fireroasted
20
Mar 27, 2017 08:17 AM
doinitevo9style
Jun 27, 2011 03:21 PM
KevOVIII
18
Nov 10, 2005 08:05 AM
