short shifter without cutting
Old Oct 6, 2005 | 12:34 AM
ctx2000's Avatar
hai...........is there anybody know about the short shifter install without cutting the shifter base?
Old Oct 6, 2005 | 12:45 AM
edwin's Avatar
get the new OEM EVO Shifter Retainer
http://www.lancershop.com/customer/p...6&cat=6&page=1
Old Oct 6, 2005 | 12:55 AM
ctx2000's Avatar
is not the retainer is the shifter base, i know that you need the new retainer,cause the stock can take it out withot cutting the shifter.
if you follow the install set up for B&M you will see on the instruction that you need to cut the shifter base. i want short shifter without cutting the shifter base..........can anybody give me a clue,
Old Oct 6, 2005 | 12:58 AM
edwin's Avatar
I dont get it! I might not remember.. sorry man!
Old Oct 6, 2005 | 01:01 AM
ctx2000's Avatar
no problem.......
Old Oct 6, 2005 | 05:18 AM
rsboy's Avatar
WORKS short shifter kits... no cutting required and comes with a retainer.
Old Oct 6, 2005 | 05:39 AM
KazzEvo8's Avatar
The B&M tells you what to order - just do it.
Old Oct 6, 2005 | 05:51 AM
nhsean69's Avatar
Ive got a kartboy SS and i didnt have to cut anything for install. Just replace the retainer, which was provided to me by Kartboy.
Old Oct 6, 2005 | 10:38 AM
RallySport Direct's Avatar
Silver Sponsor
Yes the kartboy does not require you to cut anything for install as long as you buy a new pivot cup from Mistu part number MR246296
The only one that I have seen that requires cutting is the Perrin.
Ben
Old Oct 6, 2005 | 10:41 AM
Boltz.'s Avatar
FCOTM Winner
The B&M adjustable only requires cutting if you want a 45% reduction.
Old Oct 6, 2005 | 10:44 AM
mump's Avatar
kartboy. i love it.
Old Oct 6, 2005 | 01:45 PM
superz's Avatar
If you grind away at the metal sleeve on the stock shifter, right at the weld, then you dont need to replace anything or break/cut anything.
Old Oct 6, 2005 | 01:48 PM
joeymia's Avatar
yup thats what I did...
Old Oct 6, 2005 | 02:04 PM
Silver Sponsor
Except the stock shifter if you go back to stock
Ben
Old Oct 6, 2005 | 02:10 PM
grubiaco's Avatar
Boltz is correct. Also, long as you buy the nonadjustable short shifter from B&M you won't have to cut anything. You can also buy the adjustable one and if you want the great throw reduction you are going to have to cut. If not you don't have to cut anything, but, why would you buy and adjustable one just to have it at its lowest possible setting.
