what spark plugs are you running?
Old Jan 23, 2006 | 05:15 PM
  #76
fsugatorbait's Avatar
Originally Posted by Ev9lution
so what about BPR9ES's? Would those be too much for a fully modded evo still running on the stock turbo? When I say fully modded, i mean fully but the turbo lol... internals, i/e manifolds, ic/pipes, stand alone, hks ignition system too
Way too much. You want to the run the hottest plug your setup will allow.
Old Jan 23, 2006 | 05:23 PM
  #77
Warrtalon's Avatar
Concur. Stick with 8s at most.
Old Jan 23, 2006 | 07:20 PM
  #78
sparky's Avatar
Hmm.. I am a little confused. I have a set of BP7ES plugs but there are also BPR7ES's, BR7ES's, as well as BPR7EIX's. So, are any and all of these different NGK 7-series plugs ok to run in my basically stock, catless EVO?
Old Jan 23, 2006 | 07:41 PM
  #79
Warrtalon's Avatar
You should run the BPR7ES gapped to .026.
Old Jan 23, 2006 | 10:18 PM
  #80
Cloud's Avatar
Warrtalon,
Would you gap the 8s to .026 also? They come at .032 from NGK I believe.
Old Jan 23, 2006 | 10:21 PM
  #81
Warrtalon's Avatar
Originally Posted by Cloud
Warrtalon,
Yes, I would, but it really depends on your boost level. The larger the gap you can get away with, the better. My 8s are at .021 for 26-28psi, but I don't even think that's necessary. I could probably raise the gap to .024-.026 and be fine, but I haven't bothered yet. I think .032 would be a bit much, but you can always test it to be sure.
Old Jan 23, 2006 | 11:25 PM
  #82
Corey's Avatar
My car will spike at 22-22.5 psi and I have my BPR7eS's gapped to .26.
Old Jan 24, 2006 | 01:55 AM
  #83
Jakeg97's Avatar
still stock
Old Jan 24, 2006 | 07:23 AM
  #84
My car didnt like the portruding tip. Ive had my best luck with the BR7ES gapped at .028.
Old Jan 24, 2006 | 07:34 AM
  #85
Randy's Avatar
BPR8's gapped to .22
Old Jan 24, 2006 | 08:52 AM
  #86
Soon2BEVO's Avatar
Before my last tune I got BR8ES as request by Al. He said they were better than the BPR ones. Anyway, its been 3k since the tune/plugs so I put in an extra set of BPR8ES just to fill the gap but to be honest i did not see any difference.
Old Jan 24, 2006 | 02:35 PM
  #87
evoracer32's Avatar
wut do u guys torqe the spark plugs to
Old Jan 24, 2006 | 02:41 PM
  #88
hondafan's Avatar
i run NGK BPR7EIX's gapped at .026 and have had no issues.
Old Jan 24, 2006 | 02:53 PM
  #89
TxEvo8's Avatar
18.4 ft/lbs
Old Jan 24, 2006 | 06:13 PM
  #90
Evoryder's Avatar
Put a set of BPR7ES the other day and my car is breaking-up up top like a bad relationship, i left them pre-gapped @ .28 and slapped them in....what gap are you guys running with the 7ES ...i have meth and a customflash by Al
stock gap is .25...suggestions
