what spark plugs are you running?
i want to change them out, but was wondering what was better, replace with stock or drop down a heat range, normal mods, TBE, Buschur Intercooler, getting custom Dynoflash, Walbro FP, MBC. Any Ideas?
Hey do the BPR7EIX come pregapped? I have searched and found that some pople say they are gapped to the correct specs while others say they need to be changed. Also I have heard not to use spark plug gapper on iridium plugs, so whats the best way to gap them.... Also what size spark plug socket do I need because I was going to check my stock plugs to see how they looked and the spark plug socket I have didn't fit. Thanks for any help. I didn't want to make a new thread so hopefully someone reads this... Warrtalon are you out there???
I can't remember the spark plug socket size. I think it's 3/4", but it's the larger of the 2 standard sizes. I assume you have the smaller one (5/16")? Both sizes came in my little $30 toolset.
Originally Posted by RyanM
I'm running 1.6Bar on the stock Turbo and the BPR8EIX's made a noticeable difference. I don't think I was detonating before but I'm definitely running smoother now.
For more information:
http://www.jandssafeguard.com/tech.html
The socket size is 13/16". I run Denso Iw24 plugs, which are 1 step cooler. You may have to change them more often, say every 10,000 miles, but if you run the car hard the cooler plug will help keep cylinder temps down.
Alot of places tell you not to run Iridium plugs on turbo powered engines... why is this?..
went to Autozone and they gave me double platinum autolites... THESE PLUGS SUCK.. after I had them installed I'm getting misfire all over high rpms..
ordered NGK's... waiting for them now... uhhh ups ground..
No where around me carry NGKs damnit
Yes I tried Pep boys.
Oh well lessons learn.Pepe Boys. Napa, Murray carry NGK well at least the one here does
LoL.. i know...
<--- feeling stupid..
Yah I know Pep Boys are suppose to carry them but they don't.. I've called all the automotive stores around me and they don't have them.. so I got fed up and ordered them from lancershop
If you tell them you have an Evo.. they won't say anything about NGK's..
I usually tell them I'm looking for plugs on a 1990 GSX turbo Eclipse and then NGK comes up....
