Clutch does not engage, restart car and it works HELP
Old Oct 6, 2005 | 10:20 PM
tobz's Avatar
Question PLEASE HELP Tried everything. Clutch does not engage, restart car and it works HELP
I drove my car hard for the evening. The next day the car will not engage the clutch. Restart the car and the clutch works, disengage it again and it will not go into any gear??
Any ideas??????
Old Oct 6, 2005 | 10:24 PM
mrbkkt1's Avatar
more info as in is the pedal soft, hard , etc.
Old Oct 6, 2005 | 11:53 PM
tobz's Avatar
Pedal has pressure. While the car is off I can switch thru gears smooth. Really weird. Start car. Press clutch in, goes into gear like butter.
Take car out of gear, engage clutch, nothing I get locked out of all the gears. Shut car off, restart same thing??
Old Oct 7, 2005 | 09:30 AM
tobz's Avatar
Anybody
Old Oct 7, 2005 | 09:32 AM
vboy425's Avatar
hopefully it's not what i think it is, but if it is what i think it is, it going ot cost alot of money and hopefully warrnty cover it.
Old Oct 7, 2005 | 09:37 AM
F&I-EVO's Avatar
Is you **** of $hit Mitsu Evo 8!
Old Oct 7, 2005 | 09:53 AM
mac_05evo's Avatar
What do you think it is???
Old Oct 7, 2005 | 11:01 AM
tobz's Avatar
vboy! What do think it is????
Old Oct 7, 2005 | 11:57 AM
dryad001's Avatar
My guess is the TOB.
Old Oct 7, 2005 | 12:03 PM
tobz's Avatar
Tob???
Old Oct 7, 2005 | 12:05 PM
tobz's Avatar
Throw Out Bearing. MMM Why would it work when just started, then does not work on the next try???
Old Oct 7, 2005 | 12:11 PM
cdavy's Avatar
Registered User
low fluid in the clutch master cyc? needs to be bleed?
Old Oct 7, 2005 | 12:14 PM
SilverEvo8owner's Avatar
Are you trying to engage into gear while the car is running with the clutch out?
Old Oct 7, 2005 | 12:23 PM
tobz's Avatar
NO. I'm only trying to engage while the car is running. It does seem like there might be an air bubble in there. The fluid was low when I checked it. It was right at the min.
Old Oct 7, 2005 | 01:00 PM
RyanM's Avatar
I'd check the fluid first/bleed the lines. Also check the clutch release push-rod cylinder, use the following write up
https://www.evolutionm.net/forums/sh...ad.php?t=80076
If the rod isn't seated properly in the boot it can cause this kind of a problem
