HOWTO: Clutch release cylindar push rod installation
Old May 10, 2004 | 01:11 PM
nastea's Avatar
Ok i put in my stainless steel clutch line (THIS TOOK FOREVER) as my hands are big, and that wasn't really the issue, the banjo bolt has to be exactly square, there is a trick to it, you just need to push all the slack toward the firewall so it stops, then it will line up properly.
Anyway on to the HOWTO !!!
Clutch Push Rod, which is 1/4 inch shorter so that the clutch will dis-engage more. It is picked up from lancershop.com.
This is the piece i'm talking about
here they are side by side
Removal:
Remove your intake, and battery tray:
next remove the clutch release cylinder:
now that is is removed manuver it so you can pull the boot off:
Close up of boot with stock push rod into it:
Remove the stock rod by pushing it out, and then place the new rod into the boot:
Place back onto the clutch release cylinder, and bolt everything back on, there is not bleeding nessisary unless you replaced the SS Clutch line with this as i did.
If you have any questions feel free to ask..
Old May 10, 2004 | 03:47 PM
LancerEvoMR's Avatar
Discuss thread here
vtluu
74
Dec 28, 2015 01:01 PM
F0RSAKEN
Northwest Region
31
Sep 11, 2010 12:23 PM
Warrtalon
Aug 19, 2008 07:44 PM
philippine_evos
Asian Forum
44
Aug 19, 2006 01:23 PM
theblue
May 29, 2005 08:44 PM
