installed thermostat check engine light
Well I installed a colder running thermostate drove it probably 500-600 miles with 5 passes dont the track. Just cruising along today my "Tuner light" came on went had it scanned, it said that it was runing cooler then supose to? Why would a check egine light come on for that....
thanks nick
thanks nick
The car wants to get in a closed loop situation with the 02 sensor, emmisions and proper a/f monitoring; hence the car wants to be above a lower temperature threshold with the coolant....i havent really looked into a flash that takes into account a lower temp thermostat....like hypertech for the V8's. Unless your traking your car or live in the desert or subtropical...stock stat is the best option.....imo
