Vac@ Idle
Old Oct 11, 2005 | 10:23 AM
evo8forme's Avatar
Vac@ Idle
Ok guys need your input! =)
Before I had my cams put on my VAC at Idle was at 500 mm/hg (Greddy boost gauge), but since then (after the cams, 272/272) my vac @ idle went up to 550+
is this normal??? or do I have a leak somewhere?
PLEASE ADVISE
Thanks!
Old Oct 11, 2005 | 10:38 AM
ruzs's Avatar
Vacuum
Seems weird. Normally, after cams, you should see a drop in vacuum. This is why high lift cams have to idle at higher RPM and why people complain about loosing brake pressure etc. Why yours went up is not clear.
Sigfrid
Old Oct 11, 2005 | 01:55 PM
evo8forme's Avatar
hmmm... any other ideas???
Old Oct 11, 2005 | 03:05 PM
Compjoc's Avatar
At idle mine dropped from 17 - 18 psi to about 13 psi after I installed my Works cams. Maybe your timing is off. What RPM do you idle at?
Old Oct 11, 2005 | 03:10 PM
evo8forme's Avatar
840-860
EVOEvolved
Nov 26, 2016 09:30 PM
asu11
14
Aug 16, 2016 10:19 PM
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
Oct 28, 2010 09:00 AM
03SilvaEvo
Jan 31, 2008 08:23 PM
djmikeymike
Jun 12, 2005 04:52 PM
