tdc
Old Oct 13, 2005 | 03:20 PM
JasonS's Avatar
Who knows which
On the crankshaft, which of the four marks on the side of the block is tdc?
I'm thinking its the one on the right with the 1 over the T.
Am I right?
Old Oct 13, 2005 | 03:55 PM
dan628's Avatar
I think to find top dead center you have to take off the cam gear cover, then line up the marks on the top of the cam gears....
Old Oct 13, 2005 | 07:33 PM
RyanM's Avatar
Normally, that would be correct, but the Evo marks don't line up with the stock gears. You can't use it as a point of reference.
Old Oct 14, 2005 | 01:36 PM
JasonS's Avatar
I found the correct information.
BTW, I had asked for the crankshaft TDC....read the post!
Old Oct 14, 2005 | 01:50 PM
dan628's Avatar
I know what you asked, I was just trying to help.. I guess if you don't have the belt on then I see what you mean. Well how about posting the correct info so others may learn.
Old Oct 15, 2005 | 08:58 AM
JasonS's Avatar
The marks on the engine case for lining up the crankshaft:
The mark on the crank pulley should line up with the mark on the right that has a number one over a T.
Like this: 1
T
Hope this helps anyone else.
This was also verified by piston position in the #1 Cylinder.
