AFC with Mail In Dyno Flash
Old Oct 13, 2005 | 04:21 PM
RooDizL's Avatar
If i already have a mail in dyno flash on the stock turbo and bolt ons do i need to flash it back to stock if i am goin to a 20g and AFC setup. Ive read that they dont mix well. I dont have any intentions on doin a race fuel tune right now i just want a everyday tune. Will i be ok to just add the AFC?
Old Oct 13, 2005 | 05:12 PM
G20's Avatar
G20
Based on my experience, it'll only not mix well when you put in race gas and leaning out the fuel which, indirectly, advance the timing which in combination which the timing setting from the flash maybe too high causing the ECU to pull timing. I got this when try tuning the GT35r with 110 fuel so I have to flash back to stock to solve the problem.
Old Oct 13, 2005 | 05:28 PM
Warrtalon's Avatar
Roo, where did you read that they don't mix well? There's a bunch of us that do this, and it's a recommended method. So, you decided on the 20g? I thought we talked about that? Hmm. Well, you absolutely do not want to rely on an S-AFC as your primary tuning tool for a 20g setup, whether you do the flash/s-afc combo or not.
With the base flash+safcII, you can fine tune for daily driving, then also tune for race gas (2 maps).
Old Oct 13, 2005 | 05:49 PM
RooDizL's Avatar
Well i remembered what you said about using both before but then in my readings sometime today i read two posts where ppl said they had a tough time with mail in flashes. I tried looking for it again to quote it but i cant seem to find it now. Not that i didnt believe you before I just wanted to make sure it wasnt something with the mail in tunes differing from the custom tunes. I am goin to go with the 20g instead of a bigger kit. I bought 680 injectors, a exhaust manifold, arp head studs, a AFC and AEM wideband today. Once i get all that here and squared away im goin to head to ISP.
