Upper IC pipe against radiater hose
Old Oct 19, 2005 | 12:46 PM
J8dailo's Avatar
no prob, hope everything works out
Originally Posted by lancealot72
Actually that is exactly the procedure that i used to get it in. I guess i just had the upper ic pipe a little more down that you did. i think i will try and reinstall it by raising the upper pipe slightly.
thanks,
Old Oct 19, 2005 | 01:27 PM
fishboy's Avatar
zipties, no touchy touchy
Old Oct 19, 2005 | 01:33 PM
BADEVO's Avatar
Damn I dont feel so alone anymore. I had all the same problems. Pulled the sleeve off the battery, pipe pressed up against the Rad Hose.. damn. Someone may want to link LP to this thread.
Old Oct 19, 2005 | 05:05 PM
lancealot72's Avatar
I just remembered, has anyone tried to put their undertray back on? I havent yet, but from the looks of it i dont think i can, it might be the way i have the lower pipe arranged but I reinstalled it twice and it looks like the undertray wont go back on that easily. Like i said, i havent tried it yet but
Has any of you put the undertray back on and does everything under the car fit good again?!?!
Old Oct 20, 2005 | 05:47 AM
fsugatorbait's Avatar
It will go back on but it will hit the LICP and sort of bend around it.
Old Oct 20, 2005 | 05:55 AM
BADEVO's Avatar
IT didnt just slip on, you needed to hold up some parts of it while you slipped the fastners in, but it will go back on.
Old Oct 20, 2005 | 08:41 AM
Thanks for the info on the undertray, i was a little concerned about it not going back on.
