how important is milling the head
Old Oct 27, 2005 | 05:46 AM
Az3ar's Avatar
same issue here. I will be doing mine in DEC
Old Oct 27, 2005 | 06:13 AM
kmcconn9's Avatar
Originally Posted by warp9
This really goes without asking...Its a MUST.
exactly /\ +1
Old May 28, 2007 | 05:05 PM
jkim2001's Avatar
Originally Posted by EvilDylan
found the specs jack was talking about.
"3. Check the cylinder head gasket surface for flatness by using
a straight edge and feeler gauge.
Standard value: 0.05 mm (0.0020 inch)
Limit: 0.2 mm (0.008 inch)
4. If flatness exceeds the specified limit, grind the gasket
surface to specification.
Grinding limit: *0.2 mm (0.008 inch)
*Includes/combined with cylinder block grinding
Cylinder head height (Specification when new):
131.9 − 132.1 mm (5.193 − 5.201 inches)"
Sorry to bring up an old thread. But what is the maximum (in mm) you can remove from the cylinder head? I brought up this questions recently in the Evo engine forums.
Old May 28, 2007 | 07:14 PM
kjewer1's Avatar
I seem to remember it being 8 thousanths, and the spec you quoted seems to indicate that as well ("grinding limit .2mm/.008"") I've gone further, but you start to mess up the tbelt geometry, among other risks.
JrEvoXnitez
Jul 8, 2016 05:59 PM
ethics
Canadian Forum
Feb 12, 2016 05:33 PM
kartectuning
Jan 22, 2013 08:18 AM
Murf
Mar 11, 2009 09:33 AM
