Is this BOV in backwards? Was it "crushed"?
Old Oct 18, 2005 | 10:23 PM
SP00LIN's Avatar
Was this thing installed backwards? Also, was the top crushed to allow for more boost? I was told it was, but it doesn't look like it was.
If the shots are too small, let me know and I'll blow em up.
Attached Thumbnails Is this BOV in backwards?  Was it "crushed"?-evo-stuff-016.jpg   Is this BOV in backwards?  Was it "crushed"?-evo-stuff-017.jpg   Is this BOV in backwards?  Was it "crushed"?-evo-stuff-018.jpg   Is this BOV in backwards?  Was it "crushed"?-evo-stuff-019.jpg   Is this BOV in backwards?  Was it "crushed"?-evo-stuff-020.jpg
Old Oct 18, 2005 | 10:25 PM
kimletrim's Avatar
Registered User
That is the JDM MR BOV or the Evo IX BOV. Not crushed and it is NOT backwards. Perfect.
Old Oct 18, 2005 | 10:28 PM
naucrx's Avatar
I concur!
Old Oct 18, 2005 | 10:34 PM
GraphiteMR's Avatar
Not heard of anyone crushing the MR JDM BOV. This is typically done on the 1g DSM valves to hold >17psi.
Old Oct 19, 2005 | 12:37 AM
Jakeg97's Avatar
aok
Old Oct 19, 2005 | 04:24 AM
rsboy's Avatar
That is correctly installed. Just make sure the hose is not pinched, sometimes it will cause stuttering and such.
Old Oct 19, 2005 | 06:31 AM
Warrtalon's Avatar
Hmm, I agree. It is installed properly and does not appear to be crushed. Do you have an aftermarket MAF pipe, though? I don't know if that would make a difference, but the way I see it installed, it should not flutter.
Old Oct 19, 2005 | 01:25 PM
SP00LIN's Avatar
Well thanks for the comments fellas. I'm not sure how the MAF pipe could cause the BOV to flutter. The fluttering only occurs at very low boost. If I let off the gas pedal while above 6-8 lbs of boost, I don't get the flutter. Very odd.
Maybe I should just get some very obnoxious and annoying VTA valve that shoots out neon lights when venting? j/k of course!
Old Oct 19, 2005 | 01:28 PM
GraphiteMR's Avatar
This is normal, without adequate pressure to blow off the unit will flutter and it is not an exclusive side effect of the jdm valve. Most do the same thing. Type-S, Type-R, Type-RS etc.
5k6
Mar 12, 2017 03:21 PM
awdturboscott
Nov 29, 2012 08:48 AM
xXlEVOlXx
Mar 26, 2012 03:05 PM
mcjallen
10
Jun 1, 2011 01:44 PM
krafty
14
Mar 5, 2007 11:18 AM
