don't know if clutch or tranny
Old Oct 19, 2005 | 06:27 PM
Stevolution's Avatar
I started noticing that when i am driving and i shift into third it sometimes grinds or will be in gear and then kicks the shifter back out of gear and it happens especiialy when i am revving high. does anyone know what might be wrong...if its the clutch or tranny? its an 03 evo with 22000 miles on it...
Old Oct 19, 2005 | 06:31 PM
SiCKlEyWiKeD's Avatar
mods?
Old Oct 19, 2005 | 08:28 PM
ACTman's Avatar
Try adjusting the clutch for higher release/engagement point. If that doesn't do anything for you, then you have transmission issues. There are a lot of threads on this subject if you have the patience to find them. For adjustment look at:
http://www.roadraceengineering.com/e...utchadjust.htm or http://www.evomoto.com/tech_info.php?tech_id=28.
Old Oct 19, 2005 | 08:42 PM
Nad1370's Avatar
Syncro ....worn out hence the grinding and popping out off gear.
Old Oct 19, 2005 | 10:26 PM
Ippatsu Man's Avatar
+1
Old Oct 20, 2005 | 07:51 PM
ev08buoy's Avatar
I'm not sure if your having the same problem... samething happened to me... it was the shifter cables.. they got rotted from oxidation or something... I got them cleaned and never had another problem.
Old Oct 21, 2005 | 05:17 PM
I'll have to try to check all the others out.....i guess it could be any problem like syncro or the cables maybe ill just take it into the dealership......still under warranty :P
