Having Serious Timing Belt Problem With My Car - Need Help!!
Old Oct 22, 2005 | 07:22 PM
evo8dad's Avatar
Depending on where you are in NY, I am about 1 hour north of Philly and specialize in Evolutions, stock and/or modded. It sounds like something caused the belt to rip (lose bolt possibly) or something may have whacked the pulleys (possible?). Either way, to really get a good look take off all the covers on the left side of the motor - cam cover, pulleys cover and crank pulley covers.
If you need help pm me and you can bring the car down and I will gladly take a look at it. I also don't charge an arm and a leg being that I do this on the side more like a hobby. I charge per job, meaning there is no hourly charge for diagnostics.
Adam
Boosted Solutions
Old Oct 22, 2005 | 07:26 PM
TomSlick's Avatar
See if you can borrow, rent or buy a 90 degree Borescope, pull the plugs and stick the borescope into the cylinders to see if any valves got bent. If not you lucked out. If yes you need to start thinking about building a new motor. At least that way you will know what parts you will need to be repaired.
Old Oct 22, 2005 | 07:55 PM
MaxR's Avatar
List your mods, one of them is probably the root of your problem. Also don't listen to the mechanic, they think they know it all but if you study the service manual you can probably do a better job. Mechanics are conceited blow-hards.
Old Oct 22, 2005 | 08:23 PM
EvoTech's Avatar
Who did your cams? I wonder if they may not have adjusted the tensioner correctly.
Also I doubt RPM is much more money than the stealership. I would trust them more than Mitsu.
Old Oct 23, 2005 | 08:14 AM
NocturnalEVO's Avatar
My cams were installed by TurboTrix last december.
Here are my mods:
- RNR 3” turboback with HKS muffler
- HKS 272/272 cams
- Injen intake
- Injen upper ic pipe
- HKS bov
- turboXS fmic
- arp headstuds
- ngk bpr7es plugs
- walbro fuel pump
- koyo radiator
- hallman mbc
- TurboTrix lower ic pipe
- TurboTrix reflash
- cel fix (mechanical o2 spacer)
evo8dad: do you have a shop? where exactly are you located? I'm in long island NY (about an hour and a half from NYC).
Old Oct 23, 2005 | 09:24 AM
Blue By You Evo's Avatar
damn Naj, hate to see a fellow/friend member in trouble. See if Jack will take a look before u take it anywhere. Lets get your garage cleaned up. You may have a full winter project on your hands.
Old Oct 23, 2005 | 01:55 PM
Yea I spoke to my uncle to have him pick up all his crap from our garage so I can finally put my car back in..
It'd be nice if Jack could come by and take a look if he has time
Old Oct 23, 2005 | 02:17 PM
TomSlick's Avatar
i see form you mods list you did the headstuds, Were you still running a stock timing belt and valve springs/retainers.
Tom
Old Oct 23, 2005 | 02:24 PM
TomSlick's Avatar
i see form you mods list you did the headstuds, Were you still running a stock timing belt and valve springs/retainers. I have been investigating and had decided to upgrade the whole area at the same time.
Tom
Old Oct 23, 2005 | 02:36 PM
Yea i'm running stock timing belt and valve springs/retainers.
Old Oct 23, 2005 | 03:33 PM
TomSlick's Avatar
Hi najeeb,
Works has an upgraded belt that the recommend for use with higher lift cams
http://www.worksevo.com/store/produc...products_id=67
Hopefully you just need a new belt and tensioner.
I was thinking about doing the Headbolts, springs/retainers just for extra durability.
Good Luck
Tom
Old Oct 23, 2005 | 04:21 PM
thanks a bunch man!
Old Oct 23, 2005 | 04:39 PM
Nad1370's Avatar
Did you check your t-belt if it is still tight?
Could be your tensioner that gave out and the belt is flapping againts the t-belt cover.
I'm not sure if our crank pulley is a 2 piece design. Like maybe a rubber dampener on it instead of a solid steel piece. This pro. gave out causing it to wobble.
Old Oct 23, 2005 | 04:43 PM
I wish i was a bit more technical, but I couldn't even tell you.
I need someone to look at it.. gonna take it to either mitsu or a perf. shop sometime this week..
Old Oct 23, 2005 | 05:21 PM
TurbotrixRacing's Avatar
When we do cams we dont touch the tensioner / side of the motor. I use the rod. I put his cams in almost a yr ago. And is his daily driver ..
Depending on the miles, he could of snapped the inner timing belt
The dampening pulley could be bad, many things.. But one things for certain he need to break the side of the motor down. Najeeb .. expect to pay 250-350 for this job ...anything more and you're being charged too much..
And i would tend to agree with evotech .. i wouldnt go to the dealer either.
Mark
Turbotrix
