Jun vs.HKS
Old Dec 10, 2005 | 09:42 PM
fletch's Avatar
Unhappy
Originally Posted by atlvalet
The JUN 264 should be ok, but there is not a lot of info on them (from people's feedback, not specs). Both JUN and Tomei use OEM cores, so their camshafts are hollow like the Evos. I think the Pipers may be too. THe HKS, Buddy Club, GSC are not.
I am planning on putting in Tomei cams in the next 3 or 4 months. I'm partly choosing them becuase it's a little different and becuase of the higher lift than the HKS 264s. There are no guarantees, but I think the Tomei's will put up better numbers than the HKS cams (granted, I'll need new springs and retainers).
Check your sources on this. I had a thread on this a while back and the verdict was....no one has hollow cams out right now. Adam verfified this from Jun and Tomei...
Old Dec 11, 2005 | 01:23 AM
P_A_STREET_EVO8's Avatar
jun's all day 272 with the springs and get a reflash oh men you will love the h/p.
Old Dec 13, 2005 | 02:01 AM
megatron's Avatar
damn jun cams cost an arm and a leg. does anyone know where else i can get them so i can compare prices? right now i found them for $399 each.
Old Dec 13, 2005 | 08:32 AM
en1gma19's Avatar
That's what I paid.....
Old Dec 13, 2005 | 09:31 AM
DaWorstPlaya's Avatar
I would pick Revolver cams over Jun and HKS ... infact the more I have researched the more I have found HKS parts to be mediocre ...
Old Dec 13, 2005 | 09:56 AM
sayanara's Avatar
Ok so where is the proof aka research???
Old Dec 13, 2005 | 10:50 AM
https://www.evolutionm.net/forums/sh...d.php?t=171170
Do a "search" on "revolver cams" and you find that most of the respected folks on EVOm endorse them ...
Old Dec 13, 2005 | 11:07 AM
Gruppe-S's Avatar
Jun cams are great if you are all out looking for the Max power output. As far as spec wise, the only difference is more lift - 10.8 with the same duration. However, the Jun cams aren't as aggressive as 11.5mm like the Tomei or Revolvers. I would recommend the Jun 272 if you don't care about the crazy cam roar.
Thanks,
Tom
Old Dec 13, 2005 | 12:04 PM
Tsurara's Avatar
Thanks,
Tom
Tom, could you PM me a price quote for JUN 272 cams/JUN Springs/JUN Ti retainers? I am thinking about going with a slightly larger turbo for road racing and thought those might be a good addition. I need to figure out how much I need to save
Old Dec 20, 2005 | 12:45 PM
Djstorm100's Avatar
this cam roar.. going to be like cammed V8? * wink wink*
Old Dec 20, 2005 | 01:36 PM
Ted B's Avatar
The test quoted is flawed, simply because the Revolvers have the same effective duration as the HKS 280s, not the 272s as tested.
There is no test as of the present (not that I've seen) that compares apples to apples.
I'd be cautious about recommending that cam set, simply because it gives a substantially longer effective duration than the HKS 280s, which means one should expect a very, very lopey idle and possible driveability issues. In reality, it may present some real headaches.
Old Dec 20, 2005 | 04:38 PM
Turbo13's Avatar
What would the pro's and con's be to the JUN 272's over the HKS 280's. I have HKS 272's now but will be going a different route when I get my stroker and 35R. Would the driveability issues out weight the power gains?
Old Dec 20, 2005 | 04:51 PM
en1gma19's Avatar
How the car drives has more to do with the tuner than the cams. I have the Jun 272's with a ported head and 1mm over valves and my car drives fine. Never stalls, idles solid at 1k. I don't have any issues with them at all.
Old Dec 20, 2005 | 06:27 PM
Ted B's Avatar
That's somewhat true, but only to a point. I don't see the lobe centerlines published for the JUN cams, so it's not easy to compare them to another cam set.
Do you have dyno sheets?
Old Dec 20, 2005 | 09:17 PM
timzcat's Avatar
So you are saying the Revolvers are no better then the HKS 280 cams even though there is considerably more lift? Why is it that all you do is defend your HKS 280s?
To everyone though, you need to be shopping for cams based on what you want out of the car, not what everyone else thinks is a good cam.
If it's power your after then IMHO Revolver is probably making the best cam right now. I will tell you right now though they will not provide you your grocerygetter idle you may desire but I have seen them on a bone stock ECU and it still managed to handle the idle pretty well. I agree with enigma19 that it's all about the tune. The Revolvers were designed to work with the stock turbo and as such I am able to hold more boost to redline with no change but the cams. Hopefully soon I will have an opportunity to play around with cam gears on my car to see what will smooth the idle and how it affects the power curves.
As Revolver's name gets out and people start seeing more results you will start to see more and more people going to the Revolver cams. Not to mention thier springs are top notch as designed by a spring guru himself. Revolver is not in the market just to make a buck, they put a lot of thought into design and quality. Fortunately for all of you they are competitively priced with the HKS cams.
I think in time you will start to see Revolver cams in the fastest Evos in the world.
