Extreme Duty Oil Pump
Old Oct 26, 2005 | 01:37 PM
RyanM's Avatar
http://www.racerpartswholesale.com/
Canton Accusump
Old Oct 26, 2005 | 01:43 PM
QAT-R's Avatar
Nice find. Has anyone tried this out?
Old Oct 26, 2005 | 01:47 PM
BadazzCR's Avatar
I used to run the accusump on my SCCA car... it doesn't actually pump any oil unless you loose oil pressure. I loved the accusump on my car because before you shut off the car you could close the valve leaving the oil inside the sump under pressure. So the next time you goto start the car you open the valve pre lubing the engin with a few quarts before the car starts. Secondly if you ever have an oil pump fail at high rpms or if the car is in a high G turn and you loose oil pressure you will have the added saftey with this accusump.
Old Oct 26, 2005 | 03:36 PM
QAT-R's Avatar
THAT IS BADASS...
However, it sounds like you have to turn something on or off everytime you start up or shut down, I'm getting that right? I'm assuming you put some extra oil in the sump. correct?
Old Oct 26, 2005 | 03:38 PM
BadazzCR's Avatar
no you don't have to turn anything off.. but there is a valve you can close before you turn the motor off... that will keep the oil inside the accusump under pressure.. so next time before you start your car you can open the valve releasing the oil inside of it, prelubing the motor before it starts.
Old Oct 26, 2005 | 03:46 PM
QAT-R's Avatar
I see, so it an added feature...that car in SCC Challenge should've had one, poor guy...
Thanks for clearing it up
ak47po
Dec 22, 2007 08:51 AM
A73 Lancer
Lancer Aftermarket Forced Induction Tech
13
Feb 21, 2004 09:40 PM
Crzylizard
Apr 21, 2003 02:12 PM
