Case Study # 104 - 2005 MR makes mega TQ!
Old Oct 26, 2005 | 07:43 PM
Jack @ EvoStore's Avatar
Originally Posted by DynoFlash
Custom Dyno Flash at 23 psi falling to 20.5
This is on 93 octane pumpo gas
This is the strongest 2005 I have tuned with these mods
The car was pulling so hard that the new Exedy Clutch was slipping and we had to abort the dyno session so he could put some more break in miles on the clutch
Impressive. Did you really end the run at 7,000 RPM or was there just no RPM pickup on this pull?
Old Oct 26, 2005 | 07:45 PM
joeymia's Avatar
i believe it look at the numbers i did without a 10.5 and i was at 22psi.
Old Oct 26, 2005 | 07:51 PM
Warrtalon's Avatar
Originally Posted by evoviiiyou
I agree with verification using traps at the quarter...but this still is a great curve and the torque curve = a very fun evo to drive on the street for sure. Every number or record or standard will be broken, this is the nature of things. What are you basing the 116-117mph numbers on?
Basing it off the fact that 370whp in an Evo can trap 117 when driven properly. I put the 116 in there in case the full potential isn't realized due to driving deficiencies or slight changes in scenario (air temp, humidity, coolant temp, etc). Using my 05 as an example, with 248whp I trapped 103.89 on my first and only try. With 282whp, I trapped 107.2whp on my best run out of 5, but with significant enough knock to only see 14* of timing in 4th. I dyno'd 294 and only trapped 108.5 on my first and only try in my current setup, then proceeded to mix in 4gals of 110oct and ran 113.2mph. I haven't dyno'd on the race gas setup yet, but it should be around 330-340whp, following the earlier trend. 350whp on a Dynojet typically nets 114-115mph traps, and so on...
Yes, the torque curve on this car is amazing, whether it's 290wtq or 390wtq...I admit that my curves don't look like that using my own tuning.
Old Oct 26, 2005 | 08:13 PM
Ultimate Sin's Avatar
Well, of course. The numbers aren't just impressive; they are unprecedented. A 116-117mph trap just verifies the mph, though not so much the torque. The mods, or lack thereof, have nothing to do with using the drag strip to validate dyno results. It's pretty standard fare. Indeed, these numbers are great. We just haven't seen them without race gas or meth before today.
It's been done, 2 years ago in fact. By A Turbo Trixx Customer by the name of Ron on a 2003 9.8 hot side no less with full boltons, no cat, 272's and of course an AEM EMS. He ran a 11.8 at 117MPH
Old Oct 26, 2005 | 08:16 PM
Warrtalon's Avatar
On 93 octane? That's awesome; I wasn't aware of it. Still, that's a full standalone and no cat. Not really comparable, but very impressive for pump gas (no meth, no race gas). Perhaps Al has been able to match an AEM EMS with his flash...
Old Oct 26, 2005 | 08:21 PM
evilestevo's Avatar
Very believable numbers I had a similar set up ARC intake box,Greddy PROFEC2,SAFC2,Taipan XP (Vishnu) 3" turbo back w/cat delete,Slow boy fmic,264/272 HKS cams,Vishnu cam gears (-8 intake -2 exhaust) DN Perormance twin scroll tubular header,Samco intercooler piping,Turbo XS RH34 bov,Walboro fuel pump and a Exedy twin disk.Tuned by Dave at F1 dyno 384 awhp 375 tq 23 psi tapering down to 21 0n 93 oct.
Old Oct 26, 2005 | 08:23 PM
taenaive's Avatar
amazing! He doesn't even have a test pipe Just HF cat.
Old Oct 26, 2005 | 08:31 PM
MrMejia's Avatar
incredible. Keep up the good tuning and the good work . It is a testament to the evo community. Dont be jealous out there you haters
Old Oct 26, 2005 | 08:38 PM
DCSilvrEvo's Avatar
I really DOUBT STRONGLY He was on Pump gas...
Old Oct 26, 2005 | 08:39 PM
DynoFlash's Avatar
Originally Posted by Jim_Patterson
Still shocked, he doesnt have that much into the car, his cars a keeper.
Yes indeed, its a particularly strong car. When I tuned it last week without a fuel pump he bascially ran out of fuel at 20 psi which was unusual. He decided to change from the stock air box to the HKS intake and add a fuel pump.
On this tune, I could not make an ounce more power as his injectors were 100% maxed out. The a/f is significantly leaner on this pull than I normally tune for as the injectors were all the way open.
Now he needs bigger injectors and to break in the clutch for a couple of days and we can see what it will max out at.
There is no doubt that that the individual car in question here is a very good match of parts from the factory. It has a super quiet engine which exibits almost zero knock and the turbo holds boost really well. I have a theory that much of the evo to evo power variation stems from the factory wastegate arm set up. I wish I had had more time to investigate the settings on his wastegate arm but the day was growing long.
The tune on this car was one of my best ever as the tq and power curves are literally flat. Everything came together really well and when I drove it on the road it was a real pleasure, massive low end grunt and smooth as silk.
One thing I forgot to mention, believe it or not the guy had giant 19" rims which probably cost him 15 - 20 whp to spin on the dyno.
Old Oct 26, 2005 | 08:40 PM
nickracer9's Avatar
maybe he doesn't care about the dragstrip warrtalon! maybe he doesn't want to beat the **** out of his car to hit a 117mph trap speed.
Old Oct 26, 2005 | 08:41 PM
DynoFlash's Avatar
We end the runs on the dyno at 7,000 in most cases
Old Oct 26, 2005 | 08:43 PM
Soon2BEVO's Avatar
He was. He is local around here (lives in town next to me). He is an honest guy his car was an absolute freak. I saw his dyno from Turbotrix on pump, it was 373whp on 94octane, 22psi.
Old Oct 26, 2005 | 08:44 PM
Soon2BEVO's Avatar
Man that is some crazy friggen power. Christ. Thats the power I want to put down. I havent been to the dyno since March, and since I added the BR FMIC, and I will be adding the mani, 02 and gears, hopefully I can make those numbers! God damn!
Old Oct 26, 2005 | 08:47 PM
It was at the Turbo Trixx Day I believe in 2003 at Race way park, or was it 04? Either way it is on this site and PM Marc from turbo trixx, he will give ya the details.
