Boost leak? Please Help.
Old Oct 28, 2005 | 06:05 AM
r.m.s.'s Avatar
I have an 03 as well and my car is running like crap too. The car will usually hit 17psi and then fall to 15 or it will occasionally spike at 20 and it feels way slower getting up there and then it tappers down to 14-16, the car feels extremely slow. It used to run 20-19 and felt like hardly any lag, now i sit in lag all day it seems. Mods are act/fidanza thats it. The car isn't throwing any codes. Is it possible for the car to run limp mode while there is no code being thrown. I have found a small small leak from a t-fitting that the guy before me was using to run his vaccum line for boost gauge, and since it was there i put mine in there, and i've notice a small small sound when listening at idle, it was hard to hear but i know theres a small *** leak there. That wouldn't be able to cause all those problems would it. I put a zip tie on it and it wouldn't close stop it. Thanks
Old Oct 28, 2005 | 04:23 PM
bbyevo8u's Avatar
bump
i have the same thing happening to me right now i'm checking for boost leaks tomorrow
i have an exhaust leak do you think that can cause that much power loss?
Old Oct 29, 2005 | 04:03 PM
bbyevo8u's Avatar
how much power gets taking away from a exhaust leak? i have very slow spool up
p.s. the exaust leak is bad........i'm starting to think i have a boost leak too
what do you guys think can this loss of power and slow spool up be from just an exhaust leak???
Old Oct 29, 2005 | 04:29 PM
thebluesky's Avatar
Start checking conection on the intake to include the bov, then work your way to all the intercooler piping. Tighten all your existing clamps and add/replace any as necessary. Do that and let us know where it goes from there.
Old Nov 2, 2005 | 10:24 AM
r.m.s.'s Avatar
Bump. Thanks bluesky, In the process right now i will keep you posted. Thanks again.
Old Nov 2, 2005 | 10:26 AM
Curt@MrLed's Avatar
Former Vendor
a exhaust leak will not cause perf. probs...
Old Nov 2, 2005 | 01:54 PM
dan628's Avatar
just go to autozone and get a new vac line to use for the boost gauge.... If you know you have a leak then just fix it....
Old Nov 2, 2005 | 02:39 PM
sleet's Avatar
Exhaust leaks won't cause any problems, although a boost leak will. Try this to test for leaks:
http://vfaq.com/mods/ICtester.html
Old Nov 2, 2005 | 02:40 PM
electr0's Avatar
what is the problem when you can hear wierd boost noise at 2krpm... and i know im not supposed to be spooling at 2k... please help
im having the same problem peaking at 17 psi and droppping down to 14 .. this has been dyno proven on my car
Old Nov 2, 2005 | 02:54 PM
Cajun Power's Avatar
I bought a boost leak tester from fighter garage. I will be trying it out this weekend. Great product for the money. It has the gauge and everything. I don't have any major leaks but I just like to test everything to make sure.
wwwfighters-garagecom
wwwfighters-garagecom/evo.html
add the "."'s
I have never had any trouble with any of their product and they have great customer service.
Old May 27, 2006 | 08:25 AM
theEVOdream's Avatar
add the "."'s
we'll see how it is...I just bought one. Loks like a great product and never really heard of fighters garage.
smokedmustang
200
Jan 25, 2013 05:15 AM
blk2gdsm
18
Jan 25, 2012 09:02 AM
governmule
Midwest Region
May 4, 2011 09:57 PM
yikez
74
Jan 22, 2011 09:33 PM
EvoInSoCal
May 19, 2003 08:52 PM
