dryad001's MAF-less excursion
Old Nov 1, 2005 | 08:17 AM
dryad001's Avatar
Well I have the maftpro unit in hand and just reading over the directions to get this puppy installed and hopefully running by the end of the day. I did go with the speed density route so that is the info I will be offering.
Overall, it seems pretty easy to hook up, the part I think that will take the longest is to mount the AIT sensor in the UICP.
Alright here is the website that you can purchase it from www.fullthrottlespeed.com and the main site is www.maftpro.com .
Anyone who can host pics for me please pm me with the site, prostreet will only show them for x number of days.
Old Nov 1, 2005 | 08:20 AM
stvbreal's Avatar
Excellent. Curious to see the outcome. Interested in doing this myself. Right on.
Old Nov 1, 2005 | 08:22 AM
Nesiop's Avatar
PM me the price you payed for it, and what was included with what you got.
Old Nov 1, 2005 | 08:34 AM
sleet's Avatar
Sweet
Old Nov 1, 2005 | 08:35 AM
dryad001's Avatar
Just kinda of looking over the directions at this moment eating breakfast. I am using the LC-1 wideband to help clarify things. There is only 7 wires I will have to splice into the ecu harness, it would be 9 but the wideband already has the analog out and analog ground wires so that gets rid of 2 splices right there.
Old Nov 1, 2005 | 09:07 AM
dryad001's Avatar
Apparently the files are a little too large to post up so if someone want the wiring schematic let me know with your e-mail or fax number.
Old Nov 1, 2005 | 09:49 AM
Nesiop's Avatar
GraphiteEvoMR@yahoo.com
Old Nov 1, 2005 | 10:06 AM
dryad001's Avatar
OK. The wire splices that came with the kit are the one's I don't like using so I went to Radio Shack and picked up 2 pkg of the "tap-in squeeze connectors" part number: 64-3053. I have never had a problem with these ever coming apart, not sure of the others that came with the maftpro wiring.
Old Nov 1, 2005 | 11:16 AM
BoostAddicted's Avatar
how much was this unit and what all did it include?
Old Nov 1, 2005 | 11:23 AM
dryad001's Avatar
Well the wiring is 95% donr I just have to wait for Fireball to get over here because i lost my electral tape for the wideband wires.
I found a good spot right near the throttle body on my uicp to mount the AIT sensor. Map sensor is already in place.
Old Nov 1, 2005 | 11:29 AM
Nesiop's Avatar
If you could get those pics to me asap of the install etc that would be great then I could order it. Are you running the UTEC with this?
Old Nov 1, 2005 | 11:31 AM
sleet's Avatar
Good progress so far
Old Nov 1, 2005 | 12:26 PM
dryad001's Avatar
Slow down there. Pics will be posted at the end before the car is started, then I'll try and get video of the car running without the maf.
AIT is mounted in the pipe, now the PNP harness has to get run then all we have to do is get the wideband hooked up (FIREBALL WHERE ARE YOU??) and the install is done.
Old Nov 1, 2005 | 12:31 PM
joeymia's Avatar
solder those connections!!!
Old Nov 1, 2005 | 12:33 PM
joeymia's Avatar
If your going to be using this along with UTEC you will have to disable the AFR tracking.
