Case study # 107 - Another MR with big pump power
Old Nov 1, 2005 | 04:22 PM
DynoFlash's Avatar
Here is another MR with some really great power on pump gas with our 2005 Evo Dyno Flash
This is member NYCEVO who has the follwoing mods
Buschur Intake
TX's 3" exhuast
Walbro Pump
HKS 272 int / 280 exh
Forge MBC
Custom Dyno Flash
On 93 octane with exactly 21 psi peak boost he is almost at 360 whp
I think I am onto something with some new revisions I have made in the past month. Generally we are seeing power levels about 20 whp higher than we were making with the same mods a year ago through constant work and testing on the flashing parameters.
Attached Thumbnails Case study # 107 - Another MR with big pump power-mrnycevo1.jpg
Old Nov 1, 2005 | 04:24 PM
nutrulz's Avatar
Yeah, sure 280s don't make torque.
Old Nov 1, 2005 | 04:27 PM
DynoFlash's Avatar
I would say that his tq is a bit lower than it would have been with a 272 / 272 set up
In most cases with my tuning the tq is slightly higher than the whp - buit in this case the tq is slightly lower - which i would attribute to the cams
OR - maybe - the tq is the same and the whp is higher ?
Ah - I can see more testing comming along soon
Old Nov 1, 2005 | 04:28 PM
GOKOU's Avatar
wow !
This car makes more HP and TQ then my 03 with BRS4 on alky at 25 psi.
I need to sale my car
Old Nov 1, 2005 | 04:31 PM
DynoFlash's Avatar
Originally Posted by GOKOU
wow !
I believe your car was tested on the Buschur heartbreak dyno ?
BTW - do you have a 10.5 hotside in your car ?
Old Nov 1, 2005 | 04:34 PM
nutrulz's Avatar
So what is making these '05 so beasty, besides the 10.5 hotside?
Old Nov 1, 2005 | 04:35 PM
GOKOU's Avatar
No hotside and yes it was at BR.
I didn't think the hotside would made such a difference
Old Nov 1, 2005 | 04:46 PM
DynoFlash's Avatar
GoKou - your numbers at Buschur are meaningless
Take it to the track and see what it does - its the best gauge
For example - my car made 660 on this Dyno jet and only 580 on Buschur's dyno and went 9.98
Old Nov 1, 2005 | 04:47 PM
DynoFlash's Avatar
The 10.5 hot side does offer significant gains - IMHO enough to justify the extra expense
Old Nov 1, 2005 | 05:00 PM
NocturnalEVO's Avatar
Hey Al, was this the graphite MR that had problems last week?
Old Nov 1, 2005 | 06:48 PM
DynoFlash's Avatar
This is the guy - I spent many hours trying to chase down his problem - it turned out that his turbo heat shield was bent in such a way to prevent the wastgate arm from closing all the way and it would not make any boost
Old Nov 1, 2005 | 06:54 PM
kmcconn9's Avatar
damn, very very impressive numbers...
Al, how much of a difference would straight 264/264 cams make...or would you recomend straight 272's
Old Nov 1, 2005 | 07:02 PM
NYC EVO's Avatar
Ha, what a beast man. Yea Najeeb, i was having problems but ended up fixing the problem at work. Al did a great job on the tune, damn car keeps pulling strong all the way to redline. Excellent work man!
Old Nov 1, 2005 | 07:03 PM
Your headstuds and everything else was fine?
Glad to hear everythin worked out
Old Nov 1, 2005 | 07:07 PM
dubbleugly01's Avatar
wow, I bet that makes the guys you tuned between a year ago and 1 month ago feel really special.
