Shearer's new turbo kit...check it out
Old Nov 4, 2005 | 09:42 AM
RnR Racing's Avatar
Looks good Ron. I know that material must be a pain in the butt to polish.
Old Nov 4, 2005 | 11:35 AM
Shearer's Avatar
Thanks for the kind words guys!
Originally Posted by Evo8Master
Do you offer lifetime warranty on your manifolds? Any dyno numbers??? Nice pics!!!
Yes the manifolds carry a lifetime warranty for the original owners. I only have a few dyno charts for the manifold. One of them can be found HERE, this is a stock motor with studs, 280 cams, and a standard bearing 61mm. Buschur recently tuned the kit in the above pictures in Vegas and made 496hp on a Mustang Dyno, maybe David or the car owner can add some more info because that is all I really know. Most of the manifolds I sell are through other shops, such as Turbotrix and RRE, so I do not always hear of dyno numbers.
Originally Posted by Nesiop
Did you build AMS's manifold? Looks almsot identical.
Can't say that I do, AMS has there own in house fab shop. This manifold has evolved over the last year or so to what it is today. I believe the diameter of these runners are almost a 1/4" larger than what AMS uses on there T3 manifold. So building these manifolds are somewhat of a tedious task as it is held within very tight space constraints to allow for plenty of clearance of everything.
Originally Posted by Imyurturboluva
So which GT35R is being utilized in the kit? Is it a Precision, unadulterated Garrett, or some other variant? This is mucho important for me and perhaps for a few other folks. For $3700 it looks like we may have a real practical winner. Thanks in advance.
It's Precision GT35R with there 5 bolt .63 hot side and ported shroud S cover. The Garrett GT exhaust housing proves to be quite a pain to use on the EVO's since the turbine outlet takes up so much extra space and clearance with the A/C becomes quite an issue.
Thanks Ryan. The material is a definetely a pain to polish. Good thing I have a big *** buffer and some killer buffing wheels otherwise it wouldn't even be possible. I love the polished look, to bad I can't do it to every manifold.
Old Nov 4, 2005 | 01:44 PM
Shearer's Avatar
Ivey just called me with some news, 504hp/403tq on Turbotrix's dyno. Bone stock motor, pump gas, and methanol. He mangaged to break something on the dyno and might go for more after it is fixed. Woops.
Old Nov 4, 2005 | 01:49 PM
Kwman's Avatar
Beautiful work. I like it a bunch. Keep it up.
Old Nov 4, 2005 | 03:45 PM
rACerS's Avatar
nice
Old Nov 4, 2005 | 03:57 PM
Hotshot940's Avatar
looks awesome ron, i'll have to run into the shop when of these weekends when i can get home from school, you guys are always doin some crazy **** over there.
Old Nov 4, 2005 | 04:28 PM
11secEVO7's Avatar
is there enough clearance for a koyo radiator in there?
where the wastegate sits...seems it may be a little tight
Old Nov 4, 2005 | 05:04 PM
Sean@Iveytune's Avatar
Yah was going good till my dumptube burned a hole through one of the air hoses for the brake. So I had to take it apart and fix it, by the time that was done everyone was ready to go home so called it a day, took it on the street and blasted it.......WOW!.
Sean
Old Nov 16, 2005 | 09:21 AM
Derek888's Avatar
I know what I want for christmas
Old Nov 16, 2005 | 09:29 AM
NC_EvO_GuY's Avatar
+1
Old Nov 16, 2005 | 09:34 AM
Ultimate CC's Avatar
Looks great
Old Nov 16, 2005 | 09:36 AM
TTP Engineering's Avatar
Is that a Megan header? Just Kidding...
Shearer is reknowned in the DSM world for being an exceptional welder and fabricator. The collector section is awesome. How you got that diameter piping to clear the radiator is amazing. How you got it to clear the upper radiator (stock) pipe is astounding. Not many kits can do this without a "rigged" radiator pipe. Great job!
Old Nov 16, 2005 | 10:13 AM
4ringturncoat's Avatar
Is it me or is that one of the longest header tube and collector lengths out there. She must spool real nice. Bet it would work real nice on a stroker.
Old Nov 16, 2005 | 10:41 AM
05SilverEvoVIII's Avatar
Originally Posted by Soon2BEVO
That mani looks nasty!!!!
I will second that it is a marksmanship mani. wow!!
Old Nov 16, 2005 | 04:36 PM
Blue Evo 8's Avatar
subscribed!!!
