Car holds 7000RPM
Subscribe
Nov 2, 2005 | 10:26 AM
Tell me the reasons about my high RPMs???
It holds 7000rpm at idle and i can`t do anything
Intake manifold is ok
Throttle body too(closed)
What can it be?
May be TPS?
Reply 0
Nov 2, 2005 | 10:27 AM
7000 isnt idle.. tps, i.a.s. idle motor, or something in the computer..
Reply 0
Nov 2, 2005 | 10:31 AM
What can it be?
May be TPS?
That is mechanically imposible to hold 7000rpm at iddle with your throtle body close.
The other posibility is that you might have a hole in your intake manifold at least 1" in diameter or bigger acting as a throtle body other wise 7000rpm is not posible.
Check your intake manifold, you might have a hole on it or a plug that fell off or something. That is the only logibal explanation that I have..
Reply 0
Nov 2, 2005 | 10:38 AM
very strange situation....
Reply 0
Nov 2, 2005 | 12:51 PM
idle air control valve has to be stuck wide (wide, wide) open if the throttle body is truly closed. You woudln't be able to get enough air/fuel in the engine otherwise.
Reply 0
Nov 2, 2005 | 02:24 PM
That's crazy, look for the throttle cable or somthing that is stuck.
Reply 0
Nov 2, 2005 | 02:30 PM
take off the intake pipe and see if your throttle plate is stuck open
Reply 0
Nov 5, 2005 | 03:39 PM
Today started engine, RPM as always jumped to 7000, then i turned off the key but the engine was still working!!!!
Can`t understand anything!!!!!!
May be it`s ECU problem?
Reply 0
Nov 5, 2005 | 03:40 PM
take it to dealer. damn that sound some serious electrical/mechanical problem
Reply 0
Nov 5, 2005 | 04:15 PM
its the wing!!! haha, if i was you i would take it to a tuner or a dealer and get that fixed
Reply 0
Nov 5, 2005 | 04:28 PM
Quote: take off the intake pipe and see if your throttle plate is stuck open
Check throttle cable, then check where the cable casing mounts to the IM, then check... man I don't know what to tell you.
What have you check so far thats good?
Do you live where it's cold? Something frozen
Reply 0
Nov 6, 2005 | 08:46 PM
3200-3500 rpm is what an engine will hold with iac motor open all the way (100%open)is it on stand alone or stock ecu
Reply 0
Nov 13, 2005 | 07:06 AM
Crazy!!!
It was TPS blowed up!
Reply 0
Subscribe
