need help with which fluids to use
Old Nov 2, 2005 | 08:16 PM
Derek888's Avatar
Can I use the redline gear oil for the transaxle and transfer oil? And for the LSD the Cusco one will work? I dont know the difference between the Redline gear oil and MT90 oil. The ones in the pic are the only ones that I can find here. Let me know if those will work.
Old Nov 2, 2005 | 08:18 PM
Jin4g63's Avatar
bump
Old Nov 3, 2005 | 12:49 AM
Derek888's Avatar
bump
Old Nov 3, 2005 | 07:30 AM
Derek888's Avatar
bump
Old Nov 3, 2005 | 07:34 AM
bigfishs's Avatar
Go to lancershop.com. Most people use OEM mitsu diaqueen for the transfercase and diff. BG syncroshift for the tranny seems to be popular and improves shifts.
Thats what I plan to do.
Old Nov 3, 2005 | 07:43 AM
jerdeitzel's Avatar
actually either one of those will work. I'd stick with the redline. I use royal purple myself. I do use the bg for the tranny tho. Don't let anyone tell you that you "have" to use the mitsubishi diaqueen. As long as u use something that is gl-5 your fine.
Old Nov 3, 2005 | 07:47 AM
Derek888's Avatar
ok so your saying the redline will work for both the transaxle and transfer oil? Do you think the Cusco LSD will work for the LSD? I read somewhere that GL-4 is actually better than GL5
Old Nov 3, 2005 | 08:02 AM
sierrany's Avatar
Search for prevoius threads on this...especially the ones that cover replacing clutches
Apparently if you use the wrong fluid in the transfer case (the same one used for the tranny) you will corrode the bearings.
I beleive GL4 goes in the T-Case and GL5 in the Tranny
Old Nov 3, 2005 | 08:03 AM
sierrany's Avatar
And i am almost certain that whatever is used in the T-Case can be used in the diffs
Old Nov 3, 2005 | 08:20 AM
jerdeitzel's Avatar
okay i've done alot of research into this. And my family has operated a auto parts store for over 60 years. the tranny takes gl-4, the transfer case and transaxle take gl-5. now some fluids are gl-4 and gl-5 rated. and from what i have gathered you don't want gl-5 in the tranny, just gl-4. Now this dosn't make alot of sense since some are rated as both, but it has to do with friction. now about only using diaqueen for the transfer case and transaxle. As long as its gl-5 rated use the best oil you can find, and redline is pretty good. hope this clears it up a bit
lithe's Avatar
I used Redline MT-90 for the transmission (GL4) and Redline light shockproof (GL5) for the transfer case and diffs. Everything seems fine.
Old Nov 3, 2005 | 09:23 AM
4-BNGR's Avatar
Penz Syncromesh - Manual Transaxle
RL Heavy Duty Shockproof - Transfer Case
M1 Full Synthetic - Rear Diff
That is all
Old Nov 19, 2005 | 07:33 AM
SA_Evo's Avatar
so I would need 3 quartz of Pennziol Syncromesh if I am changing my clutch?
Old Nov 21, 2005 | 10:06 AM
SA_Evo's Avatar
How about Mobil 1 gear oil and B&M LSD oil? Will they work?
Old Nov 21, 2005 | 12:55 PM
MaxR's Avatar
If it was ok to use a 75w90 gl5 in the transfer it would've said so in the manual, but it doesn't, it says straight 90 weight gl5 hypoid gear oil. Try Royal Purple Max Gear 90, its a straight 90 weight gl5 hypoid synthetic gear oil.
Gsxtremedsm
For Sale - Cars For Sale
14
Jun 19, 2008 06:08 PM
Paul Nelson
94
Feb 15, 2008 06:36 AM
anikisama
Dec 16, 2007 10:41 AM
Derek888
Oct 11, 2006 04:00 PM
RallyRedRSIX
Apr 28, 2006 01:33 PM
