Greddy Upper IC Pipe Rub??
Old Nov 4, 2005 | 07:28 AM
genrec's Avatar
For those that have it....does it rub on your radiator hose or any other area, i'm thinking of getting it, but i heard it may rub?? Please confirm one way or the other.
Thanks
Old Nov 4, 2005 | 07:42 AM
DEL TURBO's Avatar
It doesn't rub the radiator hose, but it will lay against the side of the stock battery. I have a slightly smaller Optima battery and it's almost touching the positive terminal.
Old Nov 4, 2005 | 07:45 AM
genrec's Avatar
hmm....so would you say the fitment is poor and look to another brand??
Old Nov 4, 2005 | 08:20 AM
bigjhoney's Avatar
Ive had fitment problems with 2 diff. brands and just stuck to the stock pipe because the power gains aint worth it.
Old Nov 4, 2005 | 09:26 AM
ev08buoy's Avatar
Mine fits fine after moving the battery tray a tad, It is a tight fit but doesn't "rub" against anything... also you'll need a plug to cover that 2nd hole on the pipe for JDM Evo's,... I got a rubber plug from Home Depot.
Old Nov 6, 2005 | 03:43 PM
DEL TURBO's Avatar
I wouldn't say the fitment is poor. I use my Dremel to remove a couple small bumps in the right side of the battery tray. I was able to move the battery about 1" to the right. It definitely dresses up the engine bay. As far as capping the additional tube, I found that the small rubber caps, used for chair legs, fit perfectly. Got them from Home Depot.
