Which plugs with 100% Meth? still cold ones?
Old Nov 6, 2005 | 09:18 AM
smokedmustang's Avatar
Wink Which plugs with 100% Meth? still cold ones?
Now that my shake rattle and roll issues are behind me, its time to turn the wick up on the Meth injection. are the plugs the same? is the gap the same? I also have the HKS twin power module, if that matters. If this is a re-hash, I apologize, tell me where to look, or just fill me in on what plugs I should use, and what gap. Thanks in advance!
Old Nov 6, 2005 | 09:25 AM
Chris@nolimitmotors's Avatar
i run a reflash with the dli2 and my car runs the best on NGKBPR8ES with a .28 gap. the larger gap is fine because of the ignition amplifier
Old Nov 6, 2005 | 09:26 AM
VTECH8TR's Avatar
Yep same plugs. I personally use NGK BPR8ES.
o yea thats at 30 psi on pump gas with 100% methanol
Old Nov 6, 2005 | 03:06 PM
Thanks guys, I appreciate it!
Old Nov 6, 2005 | 03:12 PM
inco9nito99's Avatar
One step colder than stock...anywhere from .024-.028" gap works depending on boost. Closer gap for higher boost since misfiring usually occurs on stock ignition and high boost.
Old Nov 6, 2005 | 05:05 PM
thanks nito99, I have heard the coils blow on the 03's, I have noticed a HUGE improvement with the HKS twin power, smoother idle, and stronger rpm powerband, with the increased spark signal. Has anyone used the coil on ignitions? ie Bushurs? I think i will get one of those, and see how they work also. Any input on those?
Old Nov 6, 2005 | 06:51 PM
C.O.P's aren't necc. unless you're pushing over 450-500hp.
Old Nov 7, 2005 | 02:28 AM
did not know that, thanks for saving me the extra dough on that one! I am getting close, but not there yet.
Old Nov 7, 2005 | 04:28 AM
C6C6CH3vo's Avatar
Those guys above know more than me but I would use BR8ES gapped to
0.025 - 0.027" stock ignition/elect <22 psi
0.022 - 0.025" stock ignition/elect >22 psi
Old Nov 7, 2005 | 04:45 AM
C6C6CH3vo's Avatar
Originally Posted by NOLIMITMOTORS
i run a reflash with .... on NGKBPR8ES with a .28 gap....
Watch the decmal point everyone: .28 would be 1/4 inch gap. You must of meant .028 or, properly put as 0.028.
Old Nov 7, 2005 | 05:39 PM
I had them at 1/4 inch, the damn tip was strait down!!!!!jk, I will gap them right. Thanks again.
Old Nov 7, 2005 | 05:49 PM
TrinaBabe's Avatar
The coil on plug doesnt really do you anything. They come from a Chrysler Sebring if you wanted to know. The reason they are better is IF you run an ignition amp. By themselves they wont help too much.
Old Nov 7, 2005 | 05:57 PM
yea i meant .028, sorry for the typo
Old Nov 8, 2005 | 02:14 AM
I have the HKS twin power ignition amplifier, does that qualify? do I need one then?
