tranny grinds..
Old Nov 9, 2005 | 11:28 PM
Rcebowl's Avatar
tranny grinds..
EDIT:
when pushing my car hard .. i noticed i hear a grind between shifts. it's more or less when i'm shifting hard .. not power shifting...
mods are:
Injen intake upper pipping
TBE
De-cat
MBC
Reflash
Exedy Twin Disk w/ flywheel
Redline fluids
do u know what's up?
Old Nov 10, 2005 | 08:45 AM
ACTman's Avatar
I am not sure what you mean by "shifting hard" exactly, but I would first try adjusting the clutch at the master cylinder rod to see if there is any difference (raise the engagement/disengagement point). Clutch adjustment problems are very common on the EVO, and affect high rpm shifting first, and then other times if the adjustment is further off. I have heard of this regardless of what clutch is used. There are other problems like syncros, etc, but the most common and easiest to fix is adjustment. If adjustment isn't right, it leads to other problems.
Old Nov 10, 2005 | 09:11 AM
Rcebowl's Avatar
well btw shifting hard i just mean when i'm pushin the car hard.. and shifting as fast as i can..
Old Nov 10, 2005 | 09:14 AM
wrxrocks's Avatar
What gear, like 1-2, 2-3, 3-4, 4-5 etc.
Old Nov 10, 2005 | 12:04 PM
Rcebowl's Avatar
2-3, 3-4, dont knwo about 4-5 or 1-2 .. i normally dont hit it to hard in those gears
Old Nov 10, 2005 | 12:19 PM
05SilverEvoVIII's Avatar
Sounds like you got syncro problems just like all the other 03 evos. Only other thing it could be is your clutch. What clutch do you have, how many miles on clutch, how hard do you drive evo.
Old Nov 10, 2005 | 01:05 PM
Rcebowl's Avatar
i've noticed it pretty much whenever i got my clutch.... Exedy Twin Disk... it's only a noise.... it still shifts smooth.. you cant feel it AT ALL.. but with the music off.. and the windows down.. you can hear something grind between the shifts....
did 03's just have a syncro problem???
Old Nov 10, 2005 | 01:54 PM
They did have a syncro prob. but in your case it sounds diff. to me. I dont know how much noise you are talking about. Chatter is common in after market high performance clutches and some noise will be common.
Also even my 05 evo with 1050 miles will grind at higher rpms it is a common prob. if the prob. gets louder i will have it fixed under factory warranty. I dont know how or what the noise is you are talking about though.
