which line for accurate boost?
Old Nov 10, 2005 | 09:23 AM
Jakeg97's Avatar
Originally Posted by EVOclub4
i've spent countless hours searching and didn't come up with nEthing...any of you guys know which line i can hook up my boost gauge to for accurate readings? if there's a post on here that i missed, please point me to that direction or tell me what you guys hooked yours up to...thanks
https://www.evolutionm.net/forums/sh...ad.php?t=80842
what gauge did you get?
and are you coming to the cruise this sat?
Old Nov 10, 2005 | 11:19 AM
EVOclub4's Avatar
i got the autometer ultralite series (shows -30vac/+30psi)
the cruise......hhmmmm.....i just check on forumshawaii and the guy said he postponed it to next week because he's still thinking about the route........ill be hostin one on sat. dec. 10 during the day....so tell the peeps on 4g63hawaii about it...thanks jake...
AND THANKS TO ALL WHO REPLIED TO THIS THREAD...appreciate it very much
Old Nov 10, 2005 | 12:44 PM
Karash's Avatar
Use the right line...if you use the left line, on a very hot day your gauge will read 0 (if its electronic)
Old Nov 10, 2005 | 02:31 PM
Sgt Blamo's Avatar
When they installed my gauge, they removed the upper IC pipe, drilled & tapped it on the bottom and installed it there. It's pretty neat, as you can't see where it hooks in. I have an Autometer Pro-lite. According to it I'm making 21-22 psi @ peak boost. You can also hear the pressure increase and decrease from the gauge, sounds pretty cool too!
Old Nov 10, 2005 | 03:34 PM
bolsen's Avatar
I have a howto on my web page. I see no difference in readings where I mounted it.
Old Nov 11, 2005 | 05:52 AM
Cajun Power's Avatar
On the RIGHT!
Old Nov 12, 2005 | 10:41 PM
MrMejia's Avatar
okay now I'm confused! the 42 draft design install on the home page of this site states to do it coming from the BPV line going to the intake manifold, which is in between the manifold and valve cover on the far right next to the throttle body! Another guy says to do it from the line that directly connects to the FPR and solenoid on the far left! most people say to do it from the intake manifold to the solenoid which is in between the far left and the far right but leaning towards the left side! WHAT THA hell man.....i needa install my boost gauge and I'm going mad trying to understand where to stick it. someone please clarify where the heck the FACTORY boost line is tapped into????? PLEASSEEE so that everyone's head can clear up!
Old Nov 12, 2005 | 10:46 PM
BaLListic_EVO's Avatar
uhhhh
this is where me and others have done it works fine... its the line from the intake manifold to the BOV.....
Old Nov 13, 2005 | 08:28 AM
twinscrewed's Avatar
Thats where I tapped into also. Works great.
Old Nov 14, 2005 | 06:38 AM
C6C6CH3vo's Avatar
Me threeMy guage was also checked and confirmed accurate when I got street tuned so the BOV line is a good place.
