ACT Clutch and High RPM lockout issues ??
Old Nov 15, 2005 | 08:59 AM
ACTman's Avatar
Originally Posted by GOKOU
Dirk,
Any way to test whether I adjusted it too much? I have 3-5 months to debate about removing the restrictor
Thanks.
The best way is to actually feel for the freeplay at the rod. You should be able to tell when the rod actually makes contact with the piston in the master cylinder, then back it off from there. You can also test for preloading, by cracking a fitting loose and see if it squirts at you, but that is testing for a symptom, not finding a cure.
Old Nov 15, 2005 | 09:03 AM
ACTman's Avatar
Originally Posted by Cajun Power
...I always get locked out above 6K rpm. I am going to try and adjust the rod on the tranny. I will let you guys know what I find. I cant run faster than 12.7 / 115 due to the loss of momentum during my looooooong shifts.
The adjustment is at the pedal, not the transmission. We have some simple instructions that come with the clutch and you can also look at these sites for more detailed information:
http://www.roadraceengineering.com/e...utchadjust.htm
http://www.evomoto.com/tech_info.php?tech_id=28.
Old Nov 15, 2005 | 09:33 AM
LIFER's Avatar
I have mine adjusted all the way out... I ran a 1.65 60ft 11.8@116 on my stock turbo w/smooth perfect shifts. But its wierd some days the lock-out dosent exist no matter how high I shift and other days it locks out over 7k everytime. It must be heat related
Old Nov 15, 2005 | 10:01 AM
GOKOU's Avatar
Dirk,
I think I understand what you're trying to say and believe there is some free play left
Lifter,
When you say all the way out does this mean 0 thread left on the nut side of the rod? Wow!
Old Nov 15, 2005 | 10:04 AM
LIFER's Avatar
actually it is so far out that the bolt is halfway through the nut.
Old Nov 15, 2005 | 10:07 AM
GOKOU's Avatar
Originally Posted by LIFER
actually it is so far out that the bolt is halfway throgh the nut.
Damn! NO issues yet??
I was scare of the preload thing that Dirk mention so I didnt go that far. I might need to try this next time I'm at the track. I just hope I don't break something
Old Nov 15, 2005 | 10:39 AM
ACTman's Avatar
Counting threads is a waste of time IMO, since each vehicle is different.
Old Nov 15, 2005 | 03:40 PM
GOKOU's Avatar
Dirk,
Does this mean I can adjust until the lock-out is gone keeping in mind the preload thing?
Old Nov 15, 2005 | 04:15 PM
ACTman's Avatar
Yup! Unless something is wrong, you should be able to find a point that will shift while the engine is screaming that is not preloading the hydaulics. You will probably have to get used to it being on the high side, but it beats lockout. Keep in mind that if the parts are badly warped or some other issue, the adjustment may be way out of whack or no about of adjustment will be enough.
Old Nov 15, 2005 | 06:10 PM
KazzEvo8's Avatar
Given that thinking, an extender for the shaft *could* be useful?
Old Nov 15, 2005 | 07:07 PM
ACTman's Avatar
Maybe on the master cylinder, but on the slave cylinder it's useless. Shorten it, lengthen it, paint it neon green, it won't matter. Any change on the slave cylinder end is going to be adjusted out by the master cylinder the same way it adjusts for normal wear.
OK, time for some clutch 101: With normal wear, the disc gets thinner which causes the diaphragm fingers to move, which pushes the rod further into the slave cylinder, which pushes fluid back thru the master cylinder and into the reservoir. A longer rod will do the same thing. But it doesn't change the amount of travel needed to operate.
Some have reasoned that because the worn out stock clutch had a higher engagement point, it must have been because of the rod being in a different position. This is FALSE. The reason why the engagement point is higher on a worn out clutch is because there is so little clamp load left to hold onto the disc, that it doesn't take much effort or foot travel to overcome this load and release the clutch. Of course that is not the case with a longer rod since the clamp load, etc has not changed.
Old Nov 15, 2005 | 08:13 PM
KazzEvo8's Avatar
Awesome, thanks for the education!
brusinn
Oct 3, 2014 06:51 PM
whitet777
50
May 17, 2012 03:40 PM
Boost_Inspired
Mar 13, 2011 12:32 PM
Nasty Evolution
78
Oct 27, 2010 09:55 PM
recompile
148
Jul 12, 2009 09:23 PM
